Passive sub Xovers
Passive sub Xovers
Old 4th December 2012, 12:58 PM   #1
Rodastro883 is offline Rodastro883  United Kingdom
Default Passive sub Xovers
Hi
I have some 10" Tannoy DCs and have been trying to add subs to them but my problem is the rolloff on the Tannoys crosses over the minimum Xover frequincy on the subs and so cannot get a flat response.
The Tannoys also have the tipical port hump in response around 50Hz so with the sub starting at 50Hz min this just increses this and it all becomes a bit boomy.
The sub also resonds above 50Hz as the rolloff is 12-18 db oct and this causes phase problems.
So one idea is to add some passive 2way sub xovers I have found between the subs and the Tannoys so roling the Tannoys off aroung 70Hz before the bass hump and giving me leway to tune the subs to match.
But my issue is will the caps that rolloff the Tannoys in the external Xovers affect the values of the caps in the Tannoys Xovers thus upseting the DC Xover points?
Any advice very wecome
Old 4th December 2012, 02:44 PM   #2
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
Try closing the port. This will convert it to a Closed Box. It should remove the 50Hz peak.
Try using your active sub at between 70-100Hz. It may integrate better.
Mike
ampslab
Old 4th December 2012, 04:08 PM   #3
Hi thanks
The Tannoys have passive radiators that I have removed and blocked off this just distroyed the whole sound from the bass/mid driver.
I have also tryed porting with verious port lenghts but that gust moves the problem elsewhere in the freq range.
I have also tryed the sub at different Xover points but this just detroyes the lovely flat detaild bass response of the Tannoy.
The subs work fine with a pair of mini speakers xover at 120Hz and sound good.
What I feel may be hapening is the sub driver and the Tannoy driver plus the ports and passive radiators may all be interacting causing peaks and hollows in the sound.
The Tannoys are still audible at 20Hz allbeit quiet but the drivers are still moving causing the subs driver and port to react.
I can be crude and use a grphic EQ to force the Tannoys to play more at the low range but other distortions ocur and I may kill them.
Old 4th December 2012, 05:08 PM   #4
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Hi, in theory you should achieve a -6 dB each way on the crossover point, which is the most natural curve to our senses .
Also, in theory, a 40Hz high pass and a 40 Hz lowpass on the sub The sub should be used under 70 Hz
Old 4th December 2012, 05:26 PM   #5
badman is offline badman  United States
badman's Avatar
You COULD always convert them to bandpass.....
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 4th December 2012, 05:48 PM   #6
OK
So can I put a capacitor in line with the Tannoys to remove the bass at 70Hz?
Or will this upset the internal Xovers?
Or Better add it inline with the bass driver, after the internal Xovers?
if so what value for 8ohm driver?
Passive sub XoversHide this!Advertise here!
Apogee Diva passive xovers for sale serraniruben Swap Meet 2 7th January 2012 05:08 PM
Active vs. passive Xovers Ryan_Mc Multi-Way 14 5th November 2008 03:31 AM
Passive line level Xovers Tenson Multi-Way 2 9th August 2006 09:14 PM
series Vs parallel passive Xovers Puggie Multi-Way 10 19th April 2005 04:06 PM
Capacitors for passive xovers. JoeBob Multi-Way 1 14th December 2001 01:46 AM
