golden ratio. I dont get it
Old 6th December 2012, 03:19 PM   #61
blistard is offline blistard  Netherlands
The dutch speaker: Studio de Schop ML 1.1 was designed using the Golden Ratio and didn't use any damping. Sounded quite nice too.
http://forum.zelfbouwaudio.nl/viewtopic.php?f=4&t=11178
Old 6th December 2012, 03:55 PM   #62
Jmmlc is offline Jmmlc  France
R.I.P.
Originally Posted by speaker dave View Post
Of course. But a dimension ratio of 2 to 1 is clearly the worst possible choice if well spaced harmonics are desired.
You do understand that, right?
Hello Dave,
As you can see 1:1:2 gives very bad result (max interval between 2 following resonances >80Hz/m). But 1 : 1.5 : 2 gives not so bad result (around 30Hz/m).
For sure, while giving a good spread of the resonances frequencies, a n integer value for a ratio may produce some coincident resonances (but this doesn't affect so much the spread it has more influence on the intensity of the resonance).
I don't care in that graph if resonances overimpose one to the other. But for sure evryone should choose a ratio which is not an integer value but taken from the red line passing through the points :
1 : 1.3 : 1.5
1 : 1.5 : 2.0
1 : 1.9 : 2.5
1 : 2.3 : 3.0
1 : 2.5 : 3.5
1 : 3.0 : 4.0
So if you want replace my sentence :
"Good shapes that spread optimally the resonances frequencies seem to be :
1 : 1.3 : 1.5 ; 1 : 1.5 : 2.0, etc."
by :
"Good shapes that spread optimally the resonances frequencies are located on the red line passing through the points : 1 : 1.3 : 1.5 ; 1 : 1.5 : 2.0, etc. but you should avoid integer values of the ratios"
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 6th December 2012, 04:31 PM   #63
flg is offline flg  United States
flg's Avatar
re: Fibinacci...David S.
thanks Dave,
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 6th December 2012, 05:14 PM   #64
speaker dave is offline speaker dave  United States
speaker dave's Avatar
Originally Posted by Jmmlc View Post
Hello Dave,
Just not following your logic here at all.
You seem to be looking at the spread in Hz between one set of modes and the next. Since moving the modes away from those of one dimension eventually gets you closer to the next higher mode, there are optimums as shown by your traced red line. Still, every discussion I have seen on the subject tries to get modes to fall away from the modes of each other axis.
The goal is clearly not to have any superimposing. (Which is why cubic rooms and integer multiple dimensions are always warned against.)
Your analysis looks at modes of dimension A vs those of dimension B. It then looks at B vs. C. Optimization of those ignores the A vs. C factor. It is a 2D solution to a 3D problem.
The lower modes will be most evenly spaced with the cube root of 2 approach. (1: 1.260 : 1.587)
The table below shows this. It uses those ratios and is normalized to a dimension with 100 Hz for the first mode of the shortest dimension. The first 10 modes are shown.
1 1.26 1.587
100 79 63
200 159 126
300 238 189
400 317 252
500 397 315
600 476 378
700 556 441
800 635 504
900 714 567
1000 794 630
Where even this approach breaks down is that the higher modes start to overlap. For example the 4th harmonic of the "1" dimension is about the same as the 5th harmonic of the "1.26" dimension. (400 vs. 397)
Still this advice is given for room design because the goals are even spacing at the low end and eventualy enough modes per Octave are achieved (modal density is a desirable thing).
In the box case that we are talking about, if it mattered, we could be assured that upper range modes are dealt with via even minor damping and equal spacing of the low modes (as assured here) would be the best result.
David S.
Old 6th December 2012, 06:02 PM   #65
puppet is offline puppet  United States
If damping the box removes resonance concerns ... why shouldn't the ratio(s) being discussed lend themselves to minimizing baffle diffraction? Isn't this a bigger deal?
Old 6th December 2012, 06:30 PM   #66
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
if you build like most, by sinking the baffle, then that baffle is already very very close to your internal ratio anyway. If you build to optimise baffle instead, you can make up the internal ratio to equal the baffle ratio, using damping... It would depend on the size of the box in question but there isnt much of a discrepancy to begin with.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 6th December 2012, 06:46 PM   #67
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
forum.zelfbouwaudio.nl • Toon onderwerp - Speakers vervangen uit "Studio de Schop ML1.3"
If the speaker pictured is the one you are talking about, it is not Golden Ratio.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th December 2012, 03:23 AM   #68
phivates is offline phivates  United States
I propose 1:1.27:1.618.
Old 7th December 2012, 03:48 AM   #69
Keriwena is offline Keriwena  United States
Tell your average woodworker you want a cabinet 12" by 15 6/25" by 19 52/125", and he'll be giggling so hard you'll have to call 911.
Old 7th December 2012, 04:34 AM   #70
I see it as 12" x 15-1/4" x 19-7/16" ... this ain't a swiss watch
golden ratio. I dont get itHide this!Advertise here!
The Golden Ratio of 1.618 PrecisionAudio Multi-Way 43 11th October 2012 03:15 PM
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 08:46 PM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
Golden Box Ratio - Important or not? Ornlu Subwoofers 5 27th May 2005 06:52 AM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 08:40 PM
Copyright ©1999-2017 diyAudio
