First DIY Aristocrat - diyAudio
Old 4th December 2012, 02:30 AM   #1
Default First DIY Aristocrat
ok I realize that you should keep the same components in speakers. So i just got a aristocrat EV off of craigslist and i want to replace everything where is a good place to buy the components? Also what would you suggest that i go with??
I found this and ive been doing alot of research for the past couple of hours and i have learned alot.
https://docs.google.com/viewer?a=v&q...WiKluDmvHV28JA
EV 12SP's for Aristocrat cabinets ? kevinr Full Range 3 15th October 2012 02:31 AM
diy disco lights? (based on diy rear projection tv idea) dion_lilley Parts 0 4th July 2007 02:34 PM
Noise Reduction DIY >not gated< DIY? orson198305 Instruments and Amps 3 25th June 2006 07:24 AM
Wondering if Upcoming DIY design will work with Tubes? Cheap DIY Kits? demon2091tb Tubes / Valves 28 7th December 2005 06:51 PM
Copyright 1999-2017 diyAudio
