Anyone using well-nuts to mount their drivers?
Old 2nd December 2012, 12:55 AM   #1
Kooshball is offline Kooshball  United States
Default Anyone using well-nuts to mount their drivers?
Reading through the loudspeaker cookbook I came across a note regarding the mounting of the drivers in an isolated way using well nuts.
Has anyone here tried this and is there an audible difference? Also, where is a good source for these well nuts?
Old 2nd December 2012, 11:37 AM   #2
speaker dave is offline speaker dave  United States
speaker dave's Avatar
These should work as compliant mounts. At KEF we used a more sophisticated motor mount for 12" woofers and small rubber grommets for 8" woofers. Either approach greatly reduced the energy applied to the box and certainly reduced the audibility of box resonances.
You must put compliant foam tape around the perimeter of the woofer so that there is no metal to wood contact, as this would nulify the effect. If done correctly you should be able to press on the woofer chassis and see some deflection (say a millimeter for a hard press).
David
Old 2nd December 2012, 12:34 PM   #3
R.I.P.
Hi Speaker,
I remember the KEF compliant info, both in datasheets and in press reports on the product.
I still have the datasheets detailing the compliant mount.
No where does it mention that the driver chassis must be air tight sealed to the mounting panel.
Because of this omission of a critical detail I never tried to implement the compliant mounting.
Maybe I am just too thick to realise that some info was missing that would allow the driver to operate correctly.
regards Andrew T.
Old 2nd December 2012, 12:40 PM   #4
R.I.P.
FWIW when compliant speaker mounting went out of fashion,
due to reviews slagging off any speaker featuring it, KEF got
round the problem for a while by decoupling the driver magnet.
It is still an approach that is effectively commercial suicide.
(Except for top end B&W mids and tweeters, not bass.)
rgds, sreten.
A current approach would be drilling out the driver to use rubber
grommets and using circuit board stand offs with the driver bolts.
Decent sized washers on the front are a very good idea.
You need a foam seal around it of course, though a caulk that
remains very flexible when cured might also work quite well.
Old 2nd December 2012, 01:03 PM   #5
Originally Posted by AndrewT View Post
Hi Speaker,
Maybe....
I don't remember the particular data sheets but at KEF we would have assumed that sealing to the box was understood.
As to the press and their understanding of compliant mounting, yes some of them were offended on principle, as misguided by Linn (HORRORS, LOSS OF INFORMATION!!!)
Others got it.
David
Old 2nd December 2012, 01:16 PM   #6
David
I spent some time looking online for well nuts and what I find seems to really only apply to something being mounted in sheet metal or other thin material to get the correct hold.
http://www.hansonrivet.com/pdf2008/C...UBBER-NUTS.pdf
Check out the image in the link and you will see what I mean...so how do I get these to work in an mdf baffle?
Thx
Old 2nd December 2012, 01:48 PM   #7
pos is offline pos  Europe
pos's Avatar
What about attaching the driver to the baffle using only silicone caulk (or similar high damping caulk)?
Would that provide enough "glue" to secure a heavy driver over time?
Old 2nd December 2012, 02:01 PM   #8
It would be tricky but with some effort they might work.
As shown in metal the through hole needs to be snug on the well nut diameter. In MDF I would drill a clearance hole just equal to the diameter and then open up the back side of it for clearance, leaving just about an 1/8" of meat at the front of the baffle.
You want to retain maximum compliance so the key will not be tightening down any more than requires to compress the foam gasket you place behind the woofer.
You should glue the well nut to the cabinet surface rather than relying on expansion. This will allow you to use it a bit slacker.
See sketch.
David
Old 2nd December 2012, 02:10 PM   #9
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
Speaker Dave, you are correct with your idea and sketch. See the following site from a supplier (found with quick google search):
http://www.spaenaur.com/pdf/sectionC/C147.pdf
Old 2nd December 2012, 02:49 PM   #10
puppet is offline puppet  United States
I'd think a guy could assemble a similar fastener solution using a rubber tubing such as vacuum line hose (automotive). A length sufficiently long enough to allow full pass through of the mdf panel and enough after that to allow a small nut/washer to compress the back side that contacts the drivers chassis. A bit like a rubber toggle bolt. A truss head machine screw would be ideal with a rubber washer under the head.
This assumes that you can access the back side while mounting the drivers though.
Anyone using well-nuts to mount their drivers?Hide this!Advertise here!
Dipole idea: mount midrange drivers back to back without baffle OllBoll Multi-Way 44 24th October 2012 11:31 PM
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x Destroyer OS Swap Meet 1 22nd December 2006 06:18 AM
how to mount drivers in cabinets with CLD (constrained layer damping) structure? Spilferderber Multi-Way 15 15th November 2006 06:54 AM
flush mount drivers captainpabst Multi-Way 6 19th December 2003 02:09 PM
Help : Best way to flush mount speaker drivers and other router tips wanted?? Cacophonix Multi-Way 7 23rd April 2003 07:47 PM
