Old 13th December 2012, 06:46 AM   #11
Craigtone,
How you connected Selenium driver with Eminence Beta? You probably needed some kind of adapter? And why you decided not to use some of Eminence HF compression drivers?
Old 13th December 2012, 01:32 PM   #12
craigtone's Avatar
Originally Posted by dumptruck View Post
Oh yeah, I see it now. Really I was just prodding you to give more details about how you came up with the crossover .
Gotcha ... well I had designed one with the Excel spreadsheet and then I contacted Eminence. They forwarded my e-mail to a tech that built a "bookshelf" version of the 10" BETA 10CX with the Eminence ASD-1001. They hand tuned it on a spectrum analyzer for 2 weeks. He sent me the schematic and it is basically what they are selling as PXB2-2K5CX except that I left out the protection bulbs and am using an L-Pad instead of the fixed resistors.
Basically, it is a 2-way, 12dB/octave, 2500Hz crossover. I am not sure which slope they are using as the component values don't match what I get using the Excel sheet for any slope. BUT, when I plug their values in, I get a perfectly flat response!
I then took their values and using only air core, low DCR inductors and quality film caps ... Viola!
I listened for a few hours yesterday and am quite impressed with the sound. They are "loud" but not aggressive. The L-pad can be a bit touchy to get the level dialed in right, but once it is set, the imaging and balance was much better than I expected. I have heard people refer to the Tekton speakers as sounding "close to live" and I have to agree with that statement on the Eminence drivers. My MarkAudio's are the most neutral speaker I have ever heard but vocals are behind the drivers which makes it sound like they are beyond the front wall of my listening room whereas the Eminence put the vocalist right between the 2 drivers in the same room.
I use Norah Jones' - Come Away With Me - LP to detect aggressiveness and resonance and I am not detecting any with this setup. I don't know if it is just me, but does anyone else think that LP is not mastered properly? The CD sounds fine, but the LP can be VERY aggressive with the wrong speakers!
http://www.craigtone.com
P2, DL-103R, C521BEE, D100 Mk2, Seduction, ForePlay, ST-70, Alpair 12P Pensils
Old 13th December 2012, 01:36 PM   #13
craigtone's Avatar
Originally Posted by ivanlukic View Post
Craigtone,
The BETA series Eminence drivers have a 1-3/8"x18 thread on the back, so no adapter required.
I chose the Selenium based on a recommendation from a friend that uses them to update drivers in the Classic Klipsch speakers. Being a big Klipsch fan myself, I took his advice. That and the response curve seemed a bit "flatter" both on and off axis than the selections Eminence had to offer.
Old 13th December 2012, 01:52 PM   #14
craigtone,
I am not sure that using low loss inductors and caps will result in either better sound or lab specs. If Eminence tuned xover for standard quality components and you use, for instance, coils with lower DC resistence, you can easily get worse performance. It actually could spoil response curve (a little).
Old 13th December 2012, 01:55 PM   #15
craigtone's Avatar
craigtone,
FWIW, I did plug my DCR numbers into the spreadsheet and all appeared fine.
Old 13th December 2012, 02:55 PM   #16
craigtone's Avatar
I just realized I never uploaded the photo of the assembled cabinet!
Enjoy ...
Old 13th December 2012, 03:38 PM   #17
GM is offline GM  United States
GM's Avatar
The CD sounds fine?! All hers, and most other CDs I've auditioned in the last decade are too forward/harsh, apparently being mixed more for the confines of a moving vehicle than a typical home room, so have to use 'smiley face' EQ to tonally balance them out in room.
Interesting that modern vinyl would be even worse unless it's for DJ apps where it has to 'cut through' the ambient noise, high damping of all those absorbent bodies.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th December 2012, 03:46 PM   #18
craigtone's Avatar
LOL ... Let me re-phrase ... "The CD sounded less harsh than the LP"
For me, it is the upper midrange that makes a sound that makes me cringe akin to scratching nails on a chalkboard. With my old Klipsch RF-7's, the LP was un-listenable until I did the DeanG crossover mods and damped the plastic horns ... then it was "bearable" with just the occasional wince.
Old 22nd December 2012, 11:06 AM   #19
wuffwaff's Avatar
Craigtone,
I´m also planing to build a speaker with the Eminence Beta 10CX. First I wanted to use the APT 50 driver after reading quite a lot of positive comments on a german build project (CT235 from Klang&Ton). But looking at the specs I´m not sure. The ASD 1001looks a lot better and the Selenium you used even more so.
You said you got a flat response with the original Eminence values for the crossover. Was this calculated or measured?
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 22nd December 2012, 01:15 PM   #20
wuffwaff,
I have all parts ready to build CT235 and I think that with Beta 10CX, APT50 is optimal. You shall have better integration and better HF extension with APT50 than with other compression drivers. If you decide to use bigger cone like Beta 12CX than, probably, you could consider bigger diaphragm drivers. Also I think that the charm of phenolic drivers sound like APT50 is unsurpassed. You should not go to disproportionally big HF drivers with Beta 10CX unless you intend to misuse loudspeakers a lot.
I think that you should stick with Klang and Ton project because you have completely predictable results (measurements, etc). My room is not too big and CT235 bass loading is particularly well suited for smaller rooms (not too much low end).
FS: pair Eminence Omega Pro 15A woofers & pair Eminence PSD 2002 8 nicksgem10s Swap Meet 0 30th June 2011 12:37 PM
3.5 way towers secretsquirrel Multi-Way 15 30th November 2008 07:54 PM
FS: 10" Silver Iris (Eminence) Coaxial driver pair theAnonymous1 Swap Meet 10 18th November 2007 05:41 PM
Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application esaias Subwoofers 8 10th August 2005 05:17 AM
three-way towers wnichol Multi-Way 3 3rd December 2001 08:08 PM
Copyright ©1999-2013 diyAudio
