OB Design Suggetions
Old 30th November 2012, 06:28 PM   #1
Bozeman83 is offline Bozeman83  United States
Default OB Design Suggetions
I am looking to build my first OB speakers. I have built a pair of Frugel Horns (two actually, one from plywood to see how they come out and the second pair from cherry). The cherry ones look great and sound fantastic. There was a great amount of resources for the Frugel Horns. So I am looking a design that I could follow. I do have a few limitations/requests on size (size be dictated by my girl friend):
Baffle size about 14" wide and not taller then 4 feet.
Woofer to be no larger then 10", but would be ok using two woofers per speaker.
With those limitations, I am looking for some design ideas.
Old 30th November 2012, 06:31 PM   #2
I do like the Flagship Jamo Reference R 909 open baffle audio speaker, but something not as wide, with smaller woofers (if that is even possible).
Old 1st December 2012, 12:02 AM   #3
holdent is offline holdent  Canada
Hi Bozeman:
The defining feature of many OBs is that they are big and typically require big woofers to achieve adequate bass passively. If you are prepared to go active and equalize the bass you can use much smaller woofers and narrower baffles.
Martin King used the passive, unequalized approach when designing OBs -- see his Quarter wave site (OB Theory). His designs are wide and tall and utilize 15" or 18" woofers.
Seigfried Linkwitz uses active analog equalized designs (Linkwitz Lab - Loudspeaker Design). His Orion design uses two 10" subwoofers and an 8" woofer.
John K uses an active/hybrid approach for his designs found at his Music and Design site (Offerings). Both Linkwitz's and John K's use narrower baffles.
There is a deign thread on a very good looking Jamo r909 clone at the Audio Circle site at Plan for open baffle Jamo r909 clone. The member jonirvine went with two 15" Eminence Alpha 15As per side in a wider baffle.
Old 1st December 2012, 03:25 AM   #4
Silent Screamer is offline Silent Screamer  Australia
Trade in GFv1 for GFv2 and get much bigger woofers...
OB Design SuggetionsHide this!Advertise here!
S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range gainphile Multi-Way 28 27th May 2016 09:13 AM
OB Speaker Design hams Multi-Way 1 1st February 2009 08:31 AM
Zenith 12" alnico cabinet suggetions sawdude Multi-Way 5 8th January 2009 06:36 PM
OB XO Design Bluto Full Range 21 24th July 2008 10:00 AM
Another New OB Design ttan98 Multi-Way 1 21st November 2007 06:01 AM
