How best to destroy my Leak 600s?
Old 28th November 2012, 12:27 AM   #1
strawmanaudio is offline strawmanaudio  United Kingdom
Default Leak 600 3 way studio monitor conversion
Hi all. I've read a fair bit here and elsewhere - enough to know I'm out of my depth in a number of ways concerning how best to approach the task at hand, which is;
Converting the 600s into full range reference monitors for studio use.
This will be my first build/ retrofit, so I'd like to keep things as simple (and inexpensive) as possible, which from my reading suggests keeping the original crossovers.
I also plan on building on Bon's project - Leak Sandwich 600 project
as much as possible (adding a modern 12 inch, later if prohibitively expensive).
I suppose my first question is - can it be done? I'd like them to reach down to 30 - 35 if poss - is it possible with a 12 inch in just over 2 cubic feet of sealed cabinet?
And secondly (since I have little knowledge on driver quality), can I afford it? In the Peerless range for expample, the 12 inchers jump from about 80 pounds (just about affordable) to twice that (no chance).
Are the drivers in what appears to be low-mid price (about 125 a speaker) going to get me what I'm after?
As a reference point, they'll be competing with Acoustic Energy AE22
these my mains, and these; Monitor Audio Silver 9i loudspeaker | Stereophile.com
as my living room mains. I'd like to build something that can hold it's own against these, if not quite surpass - a different flavour is no bad thing when checking mixes.
Thanks in advance,
Andy
Last edited by strawmanaudio; 5th December 2012 at 04:52 AM. Reason: less obnoxious title
Old 29th November 2012, 03:20 AM   #2
Bon is offline Bon  Australia
Andy
The Leak sandwich woofer is a very nice sounding woofer in the 600 box. I would try and keep it if in good condition. I replaced the perished foam surround when it would have been possibly cheaper to install a new woofer. Bear in mind that the original power handling was 50 watts rms, hardly outstanding. A suitable modern alternative woofer is
The Madisound Speaker Store
I think 40 Hz lower cut-off is more realistic for a sealed 2 cu ft enclosure. Fortunately a sealed box falls off more gradually than a ported box and with care in placement the low bass can be actually stronger than the same box ported. The mid and treble are only fit for the bin IMO. If you are replacing all the drivers (and crossover), it won't be cost effective. You will be doing it just for the challenge. Still, the sandwich woofer in a sealed 2 cu ft box, has a punch that is rare in modern loudspeakers. It is also small enough for a monitor application. In fact many were used in ABC control rooms here in Australia.
Bon
"Moderation is a fatal thing. Nothing succeeds like excess." Oscar Wilde.
Old 6th December 2012, 10:17 PM   #3
Default Mid and tweeter replacement
Originally Posted by Bon View Post
The Leak sandwich woofer is a very nice sounding woofer in the 600 box. I would try and keep it if in good condition....
Thanks for that Bon, and apols for the late reply - I'm rather busy of late.
I've decided, as this is my first such project, to endeavor with a "proven design" namely yours (and probably try to upgrade at a later date).
Could you go into more detail on how you retrofitted your drivers?
Did you make any changes to the crossover? (other than replacing the elcaps as previously stated).
This is as close to your tweeter I could find;
Peerless Vifa XT25BG60-04 Tweeter
Do you think I'd be able to pop this one in instead without too much trouble? I note the impedance difference, would this require padding down IYO?;
I have a ring radiator w.spike type waveguide in my nearfields already, and I'm very pleased with the results...
Old 6th December 2012, 10:46 PM   #4
R.I.P.
Planning on eventually replacing all 3 drivers means a complete redesign.
Planning on keeping the original bass unit and x/o's with new mid and treble
units and possible L-pad tweaks to the mid and treble using budget new
mid and treble drivers makes sense, if you never change the bass units.
I'd suggest sourcing your budget drivers from here :
http://stores.ebay.co.uk/willys-hifi-loudspeaker-spares
But don't even think about competing with modern designs, just make them
better at minimal cost as a learning experience, it makes far more sense.
For good modern value and viable 3-way designs look at :
Zaph|Audio - ZDT3.5 and
https://sites.google.com/site/undefinition/tarkus
https://sites.google.com/site/undefi...diy-sunflowers
rgds, sreten.
Old 6th December 2012, 11:44 PM   #5
Thank you sreten, you make perfect sense. At this point I'd like to - as you say - improve these as best I can (with bonus points for value).
I've been reading lots, and have considered an active build, looked at many designs, but I fear I'm getting ahead of, if not confusing myself
Are you suggesting it may not be worth spending the ~ 65 pounds for the peerless mid and vifa tweeter (as referenced in Bon's build)?
Old 7th December 2012, 08:30 AM   #6
Just by coincidence, yesterday I dropped in on the folks who now own the modified Leak 600 and was very happy with how they sounded in a vinyl based system consisting of Thorens TD125, Shure 97xE, Rega RB300 and a refurbished Sansui integrated.
Getting back to the Leak, the Peerless mid was chosen because it is a perfect fit for the cardboard mid isolation tube as well as being part of a well respected series. There are several versions of this mid with different cone materials (nomex, poly and fibreglass from memory), so there is plenty of leeway for experimenting. I preferred the poly to the nomex. I have not heard the fibreglass. The tweeter was something laying around from an earlier project but I knew it well. The main thing was it fit vertically in line with the mid. The sensitivities turned out to be a good match for the woofer and I did not alter the crossover apart from replacing the elcaps. The main improvement is in isolating the woofer vibration from the mid and tweeter by attaching a super-baffle to the existing baffle with a 3 mm thick layer of glazing silicone. The super-baffle has the usual flush mounted drivers and a bass cut-out which is approx 6 mm larger than the woofer frame. Thus the woofer sits inside the super baffle cut-out and makes no direct contact with it. If you look carefully at the attached picture, the aluminium grille frame is reversed to give a better clearance to the main enclosure.
Bon
Old 7th December 2012, 12:11 PM   #7
R.I.P.
The Peerless 5" bass/mid unit is a fine unit but in some respects
an overkill for such a project. There are tweeter choices aplently.
(You don't really need a good excursion bass/mid for midrange.)
From a DIY perspective there are other drivers you could use
and various ways of sourcing them, e.g. used speakers from
local classifieds for their drive units can be very good value.
rgds, sreten.
Old 17th January 2013, 10:10 AM   #8
Default Donor speaker question.
Hi again.
This project lives again (!) due to student loan arrival.
I have decided to follow your suggestion sreten, and as such my question is as follows...
There appear to be broadly two choices (based on internet classified research) for low budget donor speakers - relatively new/ brand new bookshelves such as Wharfedale Diamond 9.0 and Tannoy Mercury series, or older (but more expensive new) pairs such as these;
Acoustic Energy Aegis One Speakers | eBay
and these;
KEF Cresta 2 Speakers (SP3303) | eBay
What would provide me with better/ more appropriate drivers for this project?
Does driver technology "trickle down" as with other technologies?
How best to destroy my Leak 600s?Hide this!Advertise here!
Help me not destroy everything and cut my fingers off! rongon Full Range 70 28th July 2012 02:04 AM
Tango XE-20-600S SE OPT for preamp ? HP8903B Tubes / Valves 2 5th March 2012 09:45 PM
How to destroy data CD-R? rif The Lounge 58 4th September 2011 04:33 PM
Best way to destroy a Subwoofer boxcustom Car Audio 56 17th July 2008 06:01 PM
Can oscillation destroy output transistors? JojoD818 Solid State 10 13th June 2003 12:32 AM
