Fiber fill vs. fiberglass vs. wool vs lined cabinet walls
Old 25th November 2012, 02:53 PM   #21
Kooshball is offline Kooshball  United States
Originally Posted by tvrgeek View Post
See my threads on stuffing tests. Summary: For a sealed box, I went back to plain old FG insulation packed pretty tight. Much tighter than I expected. Pillow stuffing was terrible. Cotton, wool, foam, and boutique stuffing worked about as well, but cost a lot more. All that hub-bub on activated carbon I consider just plain inappropriate as I want a speaker, not a de-humidifier. ( and my test showed it did not work anyway). I learned enough to not bother with more tests and no one else seemed willing to take up the next level, just argue with no facts. So I am back to working on other problems. Can't decide: Small three way with first order crossovers or another two way with the Satori and OM1.
Is there any rissue with the moving parts in a speaker and the harsh nature of fiberglass causing wear or damage?
Thx
Old 25th November 2012, 04:14 PM   #22
Cousin Billy is offline Cousin Billy  Canada
A few questions.
Are the green sound absobing insulation batts from Home Depot the same as fiberglass. I will assume FG refers to the pink insulation?.
I have a fair number of Sorbothane sheets left over from another project. Can this be used as damping along the interior walls?.
Old 26th November 2012, 04:07 PM   #23
fastbike1 is offline fastbike1  United States
Not backed. They expand to ~ 2.5"
Originally Posted by Pallas View Post
I can't tell from the website - is are the thin HD rolls backed with anything, or are they suitable as is to use as loose fill?
I was so much older then, I'm younger than that now.
Old 26th November 2012, 04:34 PM   #24
Pallas is offline Pallas  Pakistan
Thanks (ditto to Pano; your answers were different but no backing vs. easy-to-peel backing is all the same to me) and also for the heads up about their expansion. I have nowhere really to lay them out to expand - loft, with two ferocious mini-lions who I bet would love to rip this kind of stuff apart - so good to know to account for expansion during the installation.
Serious Audio Blog
Old 26th November 2012, 05:43 PM   #25
ra7 is offline ra7  United States
Kooshball, here's some info that you might find useful:
http://www.diyaudio.com/forums/multi...ml#post3086482
http://www.diyaudio.com/forums/multi...ml#post3119287
Old 26th November 2012, 07:12 PM   #26
Btw, where do folks normally buy these materials like acoustic felt, rock wool, etc?
Old 26th November 2012, 07:13 PM   #27
Originally Posted by ra7 View Post
Thanks, will check it out.
Old 26th November 2012, 07:13 PM   #28
Bonded Logic Ultra Touch recycled denim has close to the same properties as fiberglass and is a lot easier to handle.
In the U.S. the best deal is order 6 rolls online from Home Depot.
FWIW, they've relaxed their minimum for free shipping today. So a 6-pack of this stuff is free to ship today.
Serious Audio Blog
Old 26th November 2012, 07:42 PM   #29
esl 63 is offline esl 63
To reduce wall resonance, bitumen converts vibrations into heat.
Bathroom tiles glued with wisco elastic glue is also very good.
Felt or foam on the walls are menaingless!!
The air wave has no speed close to the wall.
Stuffing should be close to the speaker element!
Since the speed is highest near the membrane the stuffing works best there...
Old 26th November 2012, 07:45 PM   #30
Perhaps a system approach is the best? A heavy layer for resonance and a fiber layer to reduce reflections back through the driver?
Fiber fill vs. fiberglass vs. wool vs lined cabinet wallsHide this!Advertise here!
Sand filled cabinet walls question zmyrna Multi-Way 48 28th June 2012 10:55 AM
OB Wool vs 703 Fiberglass ? GregOH1 Multi-Way 2 27th May 2007 06:07 PM
FS: Long fiber wool mikebarney Swap Meet 1 8th February 2006 03:03 AM
Slot port. Using cabinet walls. How to correct? Help! tarnationsauce Subwoofers 3 22nd July 2005 09:53 PM
Method for attach fiberglass to MDF walls JC Fardo Multi-Way 7 13th April 2005 08:32 PM
