bass traps
bass traps
Old 27th November 2012, 04:06 PM   #21
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by theaudiophile View Post
can you explain more about this? and perhaps show a picture?
What do you think of a sealed membrane trap? It works like a drum.
The dry wall is hung on RC-1 resilient channel. there are two sheets that are only glued together with a high damping polyurethane glue. When the wall flexes, as it will at LFs, the glue is put into shear and damps the flexing. At HFs the wall is basically rigid because it is too heavy to move at HFs.
Membrane absorbers are fine if done right. Its all good and effective if the design is done right for the problem at hand. The biggest problem that I see is people using smallish absorbers, which even if they do have some LF absorption are too small to offer much damping to a large LF mode. It takes a panel the size of a wall to do much of anything at 50 Hz or so.
Earl Geddes Gedlee Website
bass trapsHide this!Advertise here!
Bass traps? simpleacoustic Subwoofers 7 30th November 2011 11:29 PM
When and how to use bass traps MalJ Multi-Way 5 15th September 2010 12:40 PM
Cylindrical Bass Traps lgreen Multi-Way 4 15th August 2007 12:01 AM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
bass traps? bostonswoop Subwoofers 3 30th March 2006 02:03 PM
