suggestion for a 15 inch, under 200$ each that is good from 35hz to 300hz
Old 21st November 2012, 09:13 PM   #1
murphythecat8 is offline murphythecat8  Canada
Default suggestion for a 15 inch, under 200$ each that is good from 35hz to 300hz
hi
im looking to build a two way with a 15 inch driver that would cover from 35 hz to 300hz and then would be crossed to a FR, the alpair 12p.
what are my options here?
Old 21st November 2012, 09:24 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Have you thought about an entry level pro style driver? What kind of cabinet?
planet10 needs your help:
Let's help Ruth and Dave
Old 21st November 2012, 09:31 PM   #3
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Not a 15", but I'll still mention this one: https://www.solen.ca/pub/index.php?c...=2&s2=1&s3=&s4=
Old 21st November 2012, 09:35 PM   #4
ScottG is offline ScottG  United States
This depends on a lot of things..
efficiency/senstivity, baffle size, cabinet volume, vent or sealed, expected low freq. character/bandwidth, etc..
Assuming you want a fair bit of gain to overcome baffle-step pressure loss I'd recommend these for your intended bandwidth and price constraint:
Eminence Legend CB158 15" Bass Guitar Speaker 290-497
Honestly though, a 15" doesn't immediately come to mind for such a pairing..
The Audax PR240M0 in a large (volume) vented cabinet does.
http://www.madisoundspeakerstore.com...nal-10-woofer/
perspective is everything
Old 21st November 2012, 10:46 PM   #5
okay, well I want a 15 inch because I have read so much about the advantage of a 15inch in the 100 to 300 hz, but I'm open for other size, but I want that big bass, and a 15 inch seems to be the way people do it.
Okay, the cabinet must not be larger/width then 18 inch. thats my only requirement, it can be quite deep but not too wide.
I dont need efficiency that much. I have two sub amps of around 150wpc and they have built in crossover.
I want the setup to be able to make a clean 30hz but im not too fussy about 25 hz. as long as it gets to 30hz.
I have no idea what cabinet I should do. I'm quite new in the diyaudio world, but I want to step up my game and go from a fullrange to a 2 way with a good sound in the critical range in the 100 to 300hz and so I decided for a 15 inch.
I will cross the FR at around 300hz with my preamp pass b1. I have a built in first order high‚ss and I could set it to 300hz.
I hope I gave enough details. ohh and for the enclosure, the 15 inch should be placed quite high because my setup is in my bedroom, quite large but still theres a bed placed at 3 feet from the speakers and the bed is 21 inch high, so I think that to get the best sound, the woofer would need to be placed around15 inch off the ground?
Should I build two different enclosure or just put both drivers in the same box?
Finally, I have a super tweeter, I might want to use it...
thanks
Old 21st November 2012, 10:53 PM   #6
why?
Old 21st November 2012, 11:03 PM   #7
I'm reading about the "magic" of the ae td15m but for my application (crossed not much higher then 300hz) that would be a overkill right?
Old 21st November 2012, 11:15 PM   #8
Originally Posted by murphythecat8 View Post
why?
Lower mass driver more "consonant" with moderate mass full-range.
Smaller baffle width (unless making them open baffle for the full-range driver).
Actually that might be a good idea - 15" with a an open baffle full-range a'la Olsher's "Basszilla". Say 9 cubic foot volume (CB15), about 18 inches wide, vented to the front with a tuning freq. of 22 Hz. That would give you plenty of spl to work with.. It would be total bass overload for a smaller room like a bedroom though.
yeah - 6 cubic foot sealed with the Audax would likely be sufficient for your needs..
basszilla - Google Search
Old 21st November 2012, 11:18 PM   #9
Speakerholic
Cal Weldon's Avatar
Make sure they will allow the extension up to 300 Hz. Many don't.
Old 21st November 2012, 11:20 PM   #10
No more than any other 15" in a bedroom.
suggestion for a 15 inch, under 200$ each that is good from 35hz to 300hzHide this!Advertise here!
looking for a good 15 inch speaker soundhead Subwoofers 4 11th February 2010 02:29 AM
ten inch subwoofers (looking for <35hz response) e-dub Car Audio 19 23rd June 2008 11:36 AM
Looking for a ~40-300Hz Horn solution with a 15" Driver Bass-Depth Multi-Way 20 1st April 2006 05:19 PM
Drivers for dipole sub up to 200-300Hz swak Subwoofers 23 15th November 2004 07:57 AM
Copyright ©1999-2017 diyAudio
