Overnight Sensations Slot Port
Old 24th November 2012, 04:57 AM   #11
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Well you certainly have the amp power. Most desktop users are using a little topping or Lepai or similar. So I wouldn't worry about effeciency.
I'd shoot for the driver with the best bass and excursion and use your computer to boost the bass as required.
If you're on a tight budget, consider the aura NS3. I haven't used it or heard it, but cheap with loads of bass. That would be much less costly than the overnight sensation. Also fire an email at Planet 10 to see what he's got for building plans and drivers. He's got lots of full range stuff.
Old 24th November 2012, 05:01 AM   #12
Oh, if on a budget, give the CSS WR125 that I linked another look. $40 for a pair. My biggest complaint with them was effeciency, but with the NAD and a tight budget, I'd put those to the top of my list.
Old 24th November 2012, 05:08 AM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
That is a very aggressive price Bob has on those... cleaning out the wharehouse. A great driver for the price. They really need a helper tweeter. I believe Bob also has a killer price on the Mark Audio ERT26. A single small cap that brings the tweeter level down to that of the WR at 12-13k would work. With the XO that high it is just adding a bit of sparkle and the ear/brain won't have much issue with the physical separatio.
Use from 4.5 litre aperiodic to 7 litre sealed or aperiodic.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th November 2012, 06:33 PM   #14
michiu is offline michiu  Canada
I thought they were sold-out on the CSS site. I would considering making the WRT125 + ERT26 if they weren't. Seems like a neat project.
I can't seem to be able to source the Aurasound NS3 in Canada, which means exorbitant shipping fees and hassle.
I'm leaning towards the Fostex or Alpair6 at the moment.
Old 24th November 2012, 08:32 PM   #15
I asked Bob at CSS about the WR125 and he said that the WR125STR (14ohm) are in stock. I've been fiddling with a WR125 + ERT26 and this is what I've got with a single 1.1uF cap as a high pass:
Old 24th November 2012, 08:35 PM   #16
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I'll say. I paid more than that at the VanIsleFest.
planet10 needs your help:
Let's help Ruth and Dave
Old 24th November 2012, 08:36 PM   #17
frugal-phile(tm)
planet10's Avatar
Next time i order from Madisound, i'm getting some NS3 for a guy in OZ,easy enuff to bump the quanitiy up. No time frame thou...
dave
Old 24th November 2012, 10:23 PM   #18
KyleinCowichan is offline KyleinCowichan  Canada
KyleinCowichan's Avatar
I've been listening to the pair of NS3s that I won at the 2011 DIY Fest for the last 2 weeks and they are growing on me. They are both in a small sealed box (~1.25L chambers for each driver). I wonder if they needed some run in time like other drivers. If you can get them cheaply they are not too bad.
KM
Last edited by KyleinCowichan; 24th November 2012 at 10:52 PM. Reason: Clarification
Old 24th November 2012, 11:36 PM   #19
cT equals piD is offline cT equals piD  United States
If the port is the same cross sectional area, then the length should stay the same.
David Weems in his book Designing, Building & Testing..... says that a rectangular (slot) port requires a different length for a given tuning frequency and having the same area as a circular port. He suggests using a simulation program for finding the correct length of a slot port.
Pete
Old 24th November 2012, 11:41 PM   #20
Speakerholic
Cal Weldon's Avatar
Or go wild... :devil:
Overnight Sensations Slot PortHide this!Advertise here!
Overnight Sensations alternatives? spaid Multi-Way 40 29th July 2015 06:55 PM
Overnight Sensations? Howard Multi-Way 15 4th July 2012 08:16 PM
Walnut Overnight Sensations Dkalsi Swap Meet 3 14th April 2011 05:33 PM
Newbie trying to layout a crossover (Overnight Sensations) steelfrog Analog Line Level 6 5th August 2010 06:30 PM
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
