Whenever I open one of Martin J king's worksheet, on the Qts expression, the program sees the Qed as a 0, and tells me "Found a singularity while evaluating this expression, you may be dividing by a zero"
and this happens even if I havnt done anything yet, just opened the worksheet.. and happens on all of them. At first I thought the problem was my pc at home, but then tryed at school, and same thing... Anyone seen anything similar? I'm using mathcad 8 explorer
Time is the best teacher; unfortunately, it kills all its students |
#2 |
I've seen lots of 'funny' things happen with these, but not this one. Have you tried inputting a value or deleting the worksheet and downloading it again?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Yhea I tryed to bypass the formula by directly applying my Qts, and I tried redownloading the whole worksheet, still the same problem
#4 |
No, you can't overide Qts, I meant hightlight and re-input/change Qes/Qms.
GM
#5 |
Well.. I worked on it, and it seems the worksheet only uses Whole numbers, doesent take account of the decimals.
it sees 0.386 as 0 and 4.256 as 4 Anyone ever seen this? It seems the program uses "," to indicate a number. but the worksheet uses dots. So i guess there must be a way to change standarts
#6 |
Ok, got it, changed my regional settings from French(canada) to english(united states)
| mathcad worksheets | brsanko | Full Range | 0 | 15th March 2009 07:53 PM |
| Mathcad help | Buzzy | Multi-Way | 1 | 10th July 2007 04:08 PM |
| MathCad Help? | edjosh23 | Multi-Way | 3 | 13th May 2005 11:38 AM |
| MathCad help | Dave Jones | Multi-Way | 4 | 19th August 2004 12:43 AM |
| MathCad | Dave Jones | Multi-Way | 12 | 17th January 2004 12:45 AM |
| Page generated in 0.07770 seconds (74.07% PHP - 25.93% MySQL) with 10 queries |
