#141 |
Thanks. It also works the other way around. Small panels can be used to redirect reflections.
By the way, I would also do band limited ETCs.
Markus |
#142 | ||
![]() Quote:
www.dipolplus.de |
#143 |
Hello everybody,
I am a newbie, I hope I am addressing the correct post. I have a loudspeaker array of 4 small speakers (each one as big as a Rubik's cube), linearly equally spaced by 2 cm (0.8 inches). I would like to play a sound source (pink noise) from the first to the last speakers, to give the illusion of a moving sound source. One trivial solution would be, for right-to-left movement: 0 0 0 1 at time t 0 0 1 0 at time t+n 0 1 0 0 at time t+2n 1 0 0 0 at time t+3n But this obviously gives me the impression of sound "jumping" from one speaker to the following. Another solution would be updating the intensities twice more frequently: 0 0 0 1 0 0 0.5 0,5 0 0 1 0 0 0.5 0.5 0 0 1 0 0 0.5 0.5 0 0 1 0 0 0 but I am not sure it is the correct way. The question is: which sound intensity should I set the speakers so that the sound is "smootlhy" perceived as moving? I guess this is related to how to create a phantom image. Please help! Thanks a lot! |
#144 |
| Omni-dipole | tinitus | Full Range | 3 | 11th February 2013 07:53 AM |
| Omni Ribbon | båndsei | Planars & Exotics | 35 | 4th October 2012 10:25 AM |
| OMNI Gallery | gainphile | Multi-Way | 69 | 1st December 2011 09:43 AM |
| A 2-way Omni experiment | bwaslo | Multi-Way | 29 | 18th July 2010 02:31 AM |
| Omni-fast | hm | Full Range | 0 | 29th July 2007 12:27 PM |
| Page generated in 1.21899 seconds (100.00% PHP - 0% MySQL) with 10 queries |
