Anyone have pics or drawings of various joinery options for attaching a thick (1.5") front baffle to the sides of curved (0.75" thick) side panels?
THX |
#2 |
Hi, same as the options for a straight joint one would presume, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
You could just do a tongue and groove if you are really concerned about strength.
Otherwise just as Streten suggested.....a butt joint. |
#4 |
There are so many ways to do it .... I'm going to be doing the same thing, and this is how I've determined I'll do it.
I'm going to create the sides by layering 3 x .25" layers over frames attached to both front and back baffles. These layers will lap over a .75" sub baffle and will probably be bonded with epoxy (for clarity, the sides will be on the outside edges of the sub baffle). The layer edges can be routed flush with a simple jig using the plane of the front baffle as the reference. A second .75" baffle will be bonded to the first baffle, overlapping it to cover the 'crude' edges of the layered sides. The angled edges of the 2nd front baffle can be cut on the table saw. |
#5 |
Hi, there are a lot more options than a butt joint, rgds, sreten.
#6 |
Ultimate Bass Cabinets Article By Jeff Poth
These use millwork L quarter rounds with butt joints (though it's more like a rabbeted joint) and strap clamps. Works pretty darned well if you cut the bracing just right.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
| curved front open baffle | pforeman | Full Range | 0 | 20th February 2009 12:38 PM |
| Enclosure w/ curved sides, need your help | MITMechE | Multi-Way | 14 | 1st April 2004 11:08 PM |
| Beginning of the end? Second project, Mini Datyon8 curved sides. | officeboy | Multi-Way | 0 | 19th January 2004 05:16 PM |
| Curved sides... | Kongen | Multi-Way | 6 | 3rd January 2004 09:14 PM |
| Seeking links to curved sides DIY loudspeakers.... | Andy G | Multi-Way | 1 | 9th June 2003 10:30 AM |
