Fostex FE203En-S and T500A-MkII in Open Baffle
Old 18th November 2012, 05:42 PM   #1
superlian is offline superlian  Norway
Default Fostex FE203En-S and T500A-MkII in Open Baffle
I am building a open baffle with theese drivers.
Does anyone have a suggestion/experience for/with the crossover?
The baffle will have a slim white metallic MDF body and a transparent acrylic plate in front. The twin woofers are Eminence Beta 15B. I use First Watt B5 Active OB crossover (Thank you Nelson)
Drawing:
Old 18th November 2012, 06:17 PM   #2
bjarnetv is offline bjarnetv  Norway
i dont have any input on the crossover, as you probably know as much as i do about the subject; but perhaps you should incorporate a stand on top of the mdf frame for the t500a-mkII to sit on?
unless you already have some genious plan that is
Old 18th November 2012, 06:34 PM   #3
Hi The drawings are premiminary without the tweeters. New drawings will come.
Fostex FE203En-S and T500A-MkII in Open BaffleHide this!Advertise here!
Fostex Tweeters : T90A, T900A, T500A usa_satriani Full Range 34 18th April 2017 05:34 AM
Fostex FE167E Help with open baffle needed jmillerdoc Full Range 4 8th December 2009 03:20 PM
Open Baffle Desktop - Fostex 4 angeloitacare Multi-Way 2 8th June 2009 10:49 AM
FS: Fostex T500A overmind Swap Meet 4 13th September 2007 01:23 PM
Offset driver - Fostex 206E in Open Baffle ? Steve M Multi-Way 3 28th June 2004 02:52 PM
Copyright ©1999-2017 diyAudio
