diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Don't know where to put this enquiry Mods>?? (http://www.diyaudio.com/forums/multi-way/223822-dont-enquiry-mods.html)
Moondog55 18th November 2012 05:45 AM
I really do not know where to put this question, but I build multi-way speaker systems so this is where i post most often.
It is often recommended to use Audacity to generate pure tones when testing drivers and I have downloaded it and used few times. Is there a downloadable plug in that will do a simple 20 to 20k sweep for this program?/'
If so can any-one provide a link, don't mind paying either if the cost is reasonable.
Still using my old dinosaur Win2k system.
Keriwena 18th November 2012 06:23 AM
While it's a lot more than you're asking for, (but still free!), you might try REW.
REW - Room EQ Wizard Home Page
You may need to get an outboard USB soundcard (about $70), but it would be very worth the cost considering what the program can do.
Moondog55 18th November 2012 06:33 AM
Interesting program
I'll try and download later
Mooly 18th November 2012 06:36 AM
I downloaded Audacity for the 1st time two days ago needing some sweeps.
It does frequency sweeps :) Select "chirp" under the generate tab.
Moondog55 18th November 2012 06:47 AM
"Chirp" doesn't exist. I think I need a new version I better upgrade
Mooly 18th November 2012 06:51 AM
Version 2.0.2
If you click help in the top tabs and "about audacity" it will say.
Moondog55 18th November 2012 06:55 AM
Thanx Mooly, I don't know why i didn't try that first. Seniors // oldtimers moment perhaps
Mooly 18th November 2012 06:56 AM
1 Attachment(s)
Your welcome :)
So have you got it showing (chirp) ? or have you an old version.
Resources saved on this page: MySQL 18.75%
