Old 17th November 2012, 06:08 PM   #1
Default Help with a 4-way filter PLEASE
I`m on a new project... the following :
A speaker with 5 drivers in it.
1) 45 cm Phillips Low
2) 2 x 20 cm ??? Mid-Low
3) 1 Sony Mid
4) 1 BM High
I can`t find a schematic for a 4 way filter. I found a pair of speakers that uses 4 way speakers quadrall 400 ...but no info on them
How should I proceed???
Are 4 way filters possible?
Old 17th November 2012, 07:22 PM   #2
I don't know where to start answering this question,
or how you expect someone to able to help you.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 17th November 2012, 07:51 PM   #3
tinitus is online now tinitus  Europe
if you haven't bought any drivers yet, think twice about it
if you already have the drivers, throw them together and try something
anything you can come up with might be as good as any other guessing
though, you might have more luck if you look at it like a 3way with sub
still 4way, but different, kind of
Old 17th November 2012, 07:57 PM   #4
rgds, sreten.
I need some help on building the filter for the speaker. its a speaker that has 5 drivers, and I read ...or I have been told to go on a 4 way filter.
but I can`t find any data about a 4-way filter.
So ...the question is..can someone help me with a schematic or something for a 4 way speaker..
or should I go with a 3 way speaker....and go ahead and connecting the 3 low speakers toghether but in different cabinets?
Old 17th November 2012, 08:01 PM   #5
http://sites.google.com/site/undefinition/diy (see if nothing else, the excellent FAQs)
http://techtalk.parts-express.com/sh...d.php?t=219617
Zaph|Audio
Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
FRD Consortium tools guide
http://web.archive.org/web/200909021...esigningXO.htm
RJB Audio Projects
http://web.archive.org/web/200909022...ve99/Spkrbldg/
Speaker Design Works
http://www.htguide.com/forum/showthread.php4?t=28655
A Speaker project
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
Humble Homemade Hifi
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
Great free SPICE Emulator : http://focus.ti.com/docs/toolsw/fold...t/tina-ti.html
2 way, 3 way, 4 way are all based on the same principles.
You start with some useful driver data and work from there.
rgds, sreten.
Old 17th November 2012, 08:16 PM   #6
xjr100 is offline xjr100  Europe
Typical way to build the speakers is to get measurement equpment and software and start you project with measuring each of your drivers in cabinet. Then you go to crossover modelling software, load measured drivers results and play with schematics to get flat response of the model. Then build prototype and measure real response of the speaker. If something wrong - rebuild crossover and measure and again and again. After - you start with listening tests of both speakers. If you do not like something - you rebuild crossover again and again... And many many iteraitions until you will be pleased with the results.
In two words - that it how it should be.
Auricap XO, Mundorf capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Old 17th November 2012, 09:29 PM   #7
I don`t have that type of equipment, nor software....and I guess neither the know-how to use them.
The best thing I can do is get some sort of ideea about the drivers spec. and after that make a filter in the aproximate range of them.
I know its not very "smar" ...but as I said...don`t have the "toys" needed.
Old 18th November 2012, 03:55 AM   #8
The best overall advice I can give is to forget about a four way and build a two way with bi amping plus a sub-woofer.
Elliott Sound Products - The Audio Pages (Main Index)
This site has details and this is the best bet as to getting a satisfactory result in your situation.
rcw
Old 18th November 2012, 12:18 PM   #9
ok..so I`m going to listen to the advices given to me here and on other forums...
I`m going to go with the 2 in 1 "speakers boxes" . a 3-way speaker and a sub sealed off from the rest of the speaker box so its not to interfer with the 3-way one.
The 3-way speaker and sub will bouth have sep. amplification.
I believe that its the best way to go.
Thanks a lot.
I`m going to upload pictures I believe from the 10th of next mounth...PAY DAY and is comming.
First order..the bords for the speakers..that i`m going to install the speakers etc etc.
I`m going to be using a 5.1 receiver (onkyo tx-ds656).
For the moment thats what I have at home. Not the best choice I know..but i`m saving money for the upgrade.
I`m going to be using its FL FR and RL RR channels for the "4 amp" required for the speakers.
The singal will be stereo for all the 4 inputs. Just gonna puna a splitter and unite the FR - RR and RL-FL with the same signal.
A little question wich at the right time will be developted into a bigger subject...what amps are required for speakers like this?
Or should I be looking in the future for a pasive 3 way speaker and an active sub?
Old 18th November 2012, 11:49 PM   #10
3-Way Classic
take a look at builders projects(bottom page)
The ultimate rumble filter - far more effective than just a high pass filter! monty78pig Analogue Source 24 25th February 2013 01:13 PM
notch filter/shelving filter for Alpair5? mondogenerator Full Range 0 29th June 2011 06:13 PM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
