"The phase coherence of harmonics in the vocal formant range, ~630Hz to 4000Hz"
Old 17th November 2012, 09:06 AM   #11
Elias is offline Elias  Finland
Elias's Avatar
Hey guys, are you missing the point ?
We can engineer a loudspeaker fulfilling the requirements. But, have you given a thought what happens when two of those (ideal) speakers are placed at the corners of an equilateral triangle and the listener being positioned at the third corner ? The conspiracy is born which is marketed to the masses as stereo
Due to interaural cross talk at the listening position the timbre and pitch is screwed up !
Valid question to be asked: Is stereo triangle Hi-Fi ?
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 17th November 2012, 09:21 AM   #12
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
The problem I see with the idea is that the vocal range is more like 150Hz to 10kHz. This is what the software analyzers show when given a voice recording. 630Hz test tone is already quite a high pitched frequency.
Old 17th November 2012, 01:33 PM   #13
markus76 is offline markus76  Germany
Banned
Originally Posted by Elias View Post
Cross talk cancelling
Not going to happen because there is no practical implementation that could attract a large audience. It would also require different production techniques. Virtually all stereophonic recordings ever made are more or less optimized (EQ, interchannel time and level differences, etc.) for 2 speaker crosstalk playback.
In my opinion the biggest problem of 2 channel stereo is that it doesn't enable enough plausible dynamic cues caused by head movements (primarily head rotation). I believe these cues are most important for delivering a realistic auditory event in the presence of conflicting cues caused by the inherent problems of common stereo.
For example omnipolar radiation will enable such cues at the expense of clarity and timbre. The question is if a certain subset of acoustic parameters is enough to enable realism while maintaining clarity and timbre.
I'm planning to do more tests in that direction.
Interesting read: http://opus.kobv.de/tuberlin/volltex...sen_philip.pdf
Old 17th November 2012, 01:44 PM   #14
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Interesting argument, but as single critical bandwidth does not yet fully determine the timbe nor pitch the comparison is made through the full freq range. And, taking into account the critical bandwidth is not a discrete value consept but a smooth continous filtering phenomena then it follows that as phase linearity is required within one band it is required along the whole freq band.
Elias,
you may have looked at slide 28, but you possibly have not understood it yet. There is a low pass at the second stage. Afterwards the phase is lost, only the envelopes are compared. And we don't talk about what you understand as critical bandwidth, but about the basilar membrane filter banks, which are rather fixed.
www.dipolplus.de
Old 17th November 2012, 01:47 PM   #15
Barleywater is offline Barleywater  United States
- Elias
Stereo is not a conspiracy, but as with all perceptions illusory mechanisms are in play.
Stereo illusion is possible because brain didn't evolve to cope with such highly correlated multiple sources, thus the glory in a choir singing as one. Humans are one of few species that pays attention to images in a mirror.
Fidelity of an information channel may be looked as temporal fidelity to source signal in time domain, or frequency and phase angle fidelity in frequency domain.
Cross talk is less of a problem then HRTF related equalization when panning phantom image element from center to side during mix. Stereo microphones with and without dummy head are illustrative.
Two speakers may be equated to light with double slit; resolving two slits is dependent on wavelength and slit separation.
Obviously, reconstruction of arbitrary three dimensional wavefront at a point in space and time requires more than two sources.
Two eyes, each 2 dimensional receivers suffice for 3-D vision. Within boundaries, two highly correlated 2-D images suffice for mind to accept illusion of 3-D scene from single perspective.
Many visual illusions exist that give insight into neural processing of vision, a particularly good one that shares much in common with hearing is illustrated with the "Magic Eye" type pictures. A single flat image has depth mask cue processing, and with a little practice, many people see the encoded 3-D image. The manner of depth mask generation impacts the ease with which the mind can lock in on the 3-D content. Depth in image ties to distance of viewer from source. Maintaining head and source orientation is important.
My first experiences with these images were tough. It took many trials and concentration. When image appeared, even blinking would cause image to disolve. With repetition I found that images appeared quicker, and could view them in relaxed state, even momentarily closing one or both eyes.
The parallels with stereo audio are very strong. Good speakers well placed allow mind to easily find and lock onto phantom image streams with little concentration. Early reflections, and speaker with poor off axis behavior force mind to decide if sound is new element/source, or if it belongs to existing process stream. When mind easily associates wall reflections with phantom image streams it ceases further processing of these sub streams, and walls tend to vanish.
When reflection become dominant, image size location and total intensity get changed much as peering through a kaleidoscope.
Andrew
Old 17th November 2012, 03:10 PM   #16
dewardh is offline dewardh  United States
May also be that local reflections mask some of the cues that would tend to localize the speakers as sound source . . . both "broadening" (or obscuring altogether) those sources, and leading the mind to give more weight to whatever cues are embedded in the recording. There seems to be a strong desire to create a "scene" to account for the origin of sounds . . . when we "know" that it can't be two boxes we fabricate an image as best we can out of the information available.
Old 17th November 2012, 03:29 PM   #17
Banned
Originally Posted by dewardh View Post
May also be that local reflections mask some of the cues that would tend to localize the speakers as sound source.
That would be bad news because if we need to rely on masking effects to increase plausibility of spatial reproduction by overriding conflicting cues then quality will most likely suffer a lot.
I like the idea of missing spatial cues that can be extracted from existing recordings and added in a yet to be defined way much better
Old 17th November 2012, 03:49 PM   #18
jcx is offline jcx  United States
The issue was not a coherence difference but the absolute value.
then maybe you need to post a quote supporting that - or are using a odd definition of coherence
I get a cross-correlation peak if I pass correlated signals through identical all pass filters - no difference - they are still coherent - same value of correlation peak
Old 17th November 2012, 03:50 PM   #19
Elias's Avatar
Originally Posted by Rudolf View Post
Elias,
The phenomena happens in the modulation domain. For that reason I suggested the usage of modulation transfer function MTF.
The basilar membrane is a mechanical resonator, and there is no 'fixed' corner freqs for each critical bands but rather they can be countinously interpolated. The only reason all the publications model the filtering actions as a bank of filters is due to savings in computational cost.
However, the point is the envelope (from which timbre and pitch are derived) can be correct only if the phases of the harmonic components are preserved through the audio reproduction chain including loudspeakers and room.
- Elias
Old 17th November 2012, 04:17 PM   #20
Rudolf's Avatar
I thought we now are talking about the basilar membrane filter banks. Those are of course real and have "fixed" middle frequencies with regard to the inner hair cells. Which does not keep them from interacting ...
Those envelopes are "correct" as long as they allow the detection of the corresponding vocal formant. Where from do you know, to what extend the envelope curve has to be preserved until this detection starts to fail? Any links?
Rudolf
www.dipolplus.de
"The phase coherence of harmonics in the vocal formant range, ~630Hz to 4000Hz"Hide this!Advertise here!
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 09:17 AM
Best "Vintage" Stereo Pres that SoftClip and lotsa Harmonics billzoe Tubes / Valves 12 30th April 2012 08:39 PM
Harmonics above 20Khz - "Hi-Fi" and the limits of human hearing percy Everything Else 62 12th March 2008 05:27 PM
which common large FR offer good vocal "reproduction"? freddi Full Range 0 23rd July 2007 12:36 AM
tangband 3" full range w/ wood phase plug? audiotang Full Range 31 5th May 2005 03:40 PM
