diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Line Array comment (http://www.diyaudio.com/forums/multi-way/223695-line-array-comment.html)
beardman 16th November 2012 04:44 PM
Line Array comment
Hello
What do you think of this idea
8 pieces 18H50,,Audiotechnology
8 pieces BG neo8s
mounted in a Line Array
Comments about this is very velcome....good or bad
C-Quenze 18 H 52 17 06 SD
Proraum Vertriebs-GmbH | Shop | BG Corp. Drivers | BG Neo8-S - NEW!
best Beardman
weltersys 16th November 2012 06:56 PM
Originally Posted by beardman (http://www.diyaudio.com/forums/multi-way/223695-line-array-comment.html#post3243973)
Hello
8 pieces BG neo8s
best Beardman
That would be a very short array, ineffective for LF pattern control.
The side by side arrangement of the woofer and tweeter is problematic, it causes asymmetrical off-axis dips and peaks.
beardman 16th November 2012 07:22 PM
how many 18H is good
can see der are several Line Array who uses side by side
is it better with symmetrical?
Copyright 1999-2017 diyAudio
