Planer and Ribbon -- difference?
Old 16th November 2012, 02:20 PM   #1
jmar is offline jmar  United States
Default Planer and Ribbon -- difference?
Pardon my ignorance but what is the difference between a planer and ribbon tweeter?
I've never used either -- I do know the ribbon uses a thin plastic film.
I need something with wide dispersion that isn't a cheap horn like I have now, so looking at these.
The "planers" seem to get great reviews (on parts express anyway).
Thanks.
Old 16th November 2012, 03:05 PM   #2
jcx is offline jcx  United States
true ribbons aren't supported on the long edges, are usually metal foil - no plastic, the metal is often corrugated to allow easy motion in the mag field airgap
planar are usually plastic film with metal foil traces, supported by all the edges, depends on the plastic elasticity for motion
wide planar may have complicated magnetic structures the sound has to pass through or just be narrow strips looking very similar to ribbons
BG have "planar ribbons" - not true ribbon drivers
Magneplan has both types
Old 16th November 2012, 03:13 PM   #3
StigErik is offline StigErik  Norway
StigErik's Avatar
A good example is the Apogee speakers. The woofer is a planar, and the tweeter a ribbon. The difference is described in jcx's post above.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 16th November 2012, 05:12 PM   #4
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
i dont get this, if a planar is supported by all sides, then why is a film laminate ribbon NOT a true ribbon?
I.e. 'planar' or 'ribbon' describe method of operation not the diaphragm composition.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 16th November 2012, 06:08 PM   #5
dacen is offline dacen  Norway
This has always confused me as well. Take a look her on BGs own info. They call it Planar magnetic ribbon. http://www.bg-speaker.de/downloads/rd-productinfo.pdf Apogee call all the speakers without dynamic bass speakers for Full Range Ribbon.
Apogee Speaker Users Website
I am confused
Old 16th November 2012, 06:23 PM   #6
pcb121055 is offline pcb121055  United States
Hi guys. I thought a magnetostat was a driver whose membrane was fully bound and magnetically driven, a ribbon was bound on the ends and magnetically driven while planar was a shape which could be implemented by magnetic or electrostatic methods. I have seen the term "planar magnetic" used pretty often... which would be a magnetostat?
Old 16th November 2012, 06:41 PM   #7
Here is what I have built several years ago. I would call both the MR/TW and the bass panel MAGNETOSTATIC as long as the driving force for the membranes is not an electromagnetic field.
https://picasaweb.google.com/tsundsd...56458436717122
Old 16th November 2012, 07:01 PM   #8
I agree. Except I substitute 'isodynamic' for planar. Magnetostat confuses me, perhas the magnets are only on the reverse of the diaphragm?
Old 16th November 2012, 08:25 PM   #9
These speakers are dynamic speakers as good as any. The principle of operation is exactly the same.Only that the magnet field is pread over a larger surface and the voice coil is running back and fourth in this magnetic field spread over the same wide surface. The magnetostatic name has just been chosen because of the resemblance with electrostatic speakers.
Old 17th November 2012, 03:39 AM   #10
Silent Screamer is offline Silent Screamer  Australia
this might give you a better visual understanding of a ribbon
RAAL ribbon replacement and tightening - YouTube
Planer and Ribbon -- difference?Hide this!Advertise here!
space blanket ribbon/planer advice needed gon Planars & Exotics 1 19th July 2006 03:48 PM
Difference between Ribbon and AMT Audist Multi-Way 6 29th January 2005 01:20 PM
Planer 3 Esra Yeknom Analogue Source 11 29th January 2004 07:14 AM
