Mission 701 baffle rattle, help me fix that
Old 15th November 2012, 06:20 PM   #1
misfits73 is offline misfits73  United Kingdom
Default Mission 701 baffle rattle, help me fix that
Hi guys,
help me fix the baffle rattle in my Missions 701, it is very annoying in low frequencies.
I'm thinking of buying a new pair of speakers cos of that but i don't think i will ever get the Mission's sound with my budget (max 150).
I have read about re-glue ing, but i dont know how to remove the front cover (baffle), which strong glue to buy and in which points to apply it.
Please help otherwise advise for speakers with such sound for 80's Heavy metal and rock,pure analogue sound thru the grooves
Old 15th November 2012, 07:09 PM   #2
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
im loosely familiar with those speakers, but not an expert. If the baffle is screwed down then try removing it and sealing with bathroom silicone, or self adhesive foam draughtproofing tape, and put it back together. It may be a speaker itself buzzing tho if they have been pushed very loud. Perhaps System7 will chime in when he sees this thread, he has an interest in speakers of that era, and likely knows your model far better than me.
It could be the grille frame, terminal plate, or crossover inside the box vibrating. Or it could be a issue with the woofer. Are you sure its the baffle?
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 15th November 2012, 10:07 PM   #3
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
The grilles appear removable on the pics on the net. Do yours look like these?
https://www.google.ca/search?q=missi...E4eniAL22YCIBA
planet10 needs your help:
Let's help Ruth and Dave
Old 15th November 2012, 10:51 PM   #4
Yes,that's it
Old 16th November 2012, 02:43 PM   #5
Speakerholic
Cal Weldon's Avatar
So if you can remove the grilles, can you not sort out where the buzz is?
Old 17th November 2012, 09:51 AM   #6
davidsrsb is offline davidsrsb  Malaysia
Check the driver bolts are tight - they can shake loose with age.
One of my Mission 752s was rattling, which turned out to be the glued joint on the side of the baffle. The glue seems to have vanished in my hot climate, so I opened up the gap and forced in epoxy resin
Old 17th November 2012, 03:26 PM   #7
Bolts are tight, the problem is the original water glue.
I dont know if i have to remove the front black cover(is that cover called baffle?) or apply glue from the inside (without removing the cover,only the drives)
Any particular glue to suggest?
Old 17th November 2012, 04:16 PM   #8
Pompey Monkey is offline Pompey Monkey  United Kingdom
I have a pair of Mission 702e's - they are essentially the same, but with extended panels to make them into a faux floorstander - a bit of a con really as the actual enclosures are the same size as yours.
One of the baffles in mine also became loose and made a really irritating buzz whenever significant bass was present in the music. To fix them I had to gain as much access to the insides as possible by removing both the connection plate on the rear of the speaker and the woofer. I really can't remember if I disconnected the the crossover or not - if I did it couldn't have been that difficult or I'd remember!
I used plenty of Araldite around the rear edges of the baffle where it butts against the wood and also (carefully!) filled in as much as possible of the small gap between the baffle and cabinet from the front. It was a bit fiddly, but then some things are...
That was at least seven years ago and they are still going strong, with daily use. However, I have had a subwoofer as part of my set-up for the last five or so years and that has probably reduced some of the stresses on the baffle/cabinet interface.
Still - seven more years for the price of an epoxy resin set can't be all bad
Please let me know how you get on.
Old 17th November 2012, 09:13 PM   #9
system7 is offline system7  United Kingdom
system7's Avatar
Araldite sounds a bit over the top if that is epoxy resin...
PVA wood adhesive is the stuff for sticking any sort of wooden material.
Evo Stik Wood Adhesive Interior 125ml:
Evo Stik Wood Adhesive Interior 125ml, 0000050403226
Best Regards from Steve in Portsmouth, UK.
Old 17th November 2012, 10:33 PM   #10
Except the baffle is plastic and the cabinet is mdf....
I've repaired one of these so experience (probably) trumps guesswork....
Mission 701 baffle rattle, help me fix thatHide this!Advertise here!
Broken Mission 701 converted in elegent floorstander w photos oaristys Multi-Way 19 20th July 2016 10:28 PM
Mission Cambridge amplifier - Mission Power Amp Module 1 Aleko Solid State 1 18th May 2011 01:14 PM
Help to fix Mission PCM II AndrewB Digital Source 19 2nd July 2008 09:36 AM
Perpetuum-Ebner PE66: To fix or not to fix... Grendel the Cat Everything Else 0 6th April 2007 05:37 AM
Mission 701 Sonus Multi-Way 0 6th November 2004 08:25 PM
Copyright ©1999-2017 diyAudio
