wide band midrange
wide band midrange
Old 15th November 2012, 05:54 PM   #1
Hylle is offline Hylle  Denmark
Default wide band midrange
I would like to have your recomendations for a very wideband midrange, with cross over I like it to be used in the frequency range from about 200Hz to 6-9 KHz.
I prefer, paper, glasfiber and kevlar cones.
Also it have to make 92-93 db sensitivity for a 8 om driver.
I have looked at Audax PR170M0, many must have used that already, or some of the other 4-6" sensitive Audax drivers.
How does the Audax PR17 series sound unfiltered?, is it agressive, nasal or open with out hardneses, I hope for the last. the upper frequency response becomes a bit bumpy, but maybe it does not sound like it.
Better it is a bit dark sounding that screaming!
Old 15th November 2012, 06:41 PM   #2
adason is offline adason  United States
adason's Avatar
I used FF125K with success
Audio Pages: The way I like speakers these days
Old 15th November 2012, 07:00 PM   #3
mondogenerator is online now mondogenerator  England
mondogenerator's Avatar
I have seen the audax used in a few high efficiency 3 ways, but havent built a system using it. Perhaps one of tangbands fullrange drivers would suit? Or perhaps visaton B200 or FRxxx range of drivers? What box type you are making will have some impact on what best suits you.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 15th November 2012, 08:12 PM   #4
Thanks for input. The smaller Fostex fullrange drivers can nok make the 92-93 db sensitivity right?
I would love to hear from some that have used the audax midranges.
Old 15th November 2012, 08:22 PM   #5
adason's Avatar
http://www.fostexinternational.com/d...pdf/ff125k.pdf
Old 15th November 2012, 08:23 PM   #6
TerryO is offline TerryO  United States
TerryO's Avatar
NOK? If you ment "not" make 92-93 dB, I believe that there are several in the 4 inch diameter size range that actually do produce that level of efficiency.
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 15th November 2012, 08:38 PM   #7
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I always thought the current crop of super Full-rangers would make for outstanding mid-range drivers.
Consulting the specs, most all of them have a rather high Efficiency Bandwidth Product......putting them squarely in the Ported enclosure class.
That said...where would you put the port???
Would there be problems with two ports on the front of a baffle?......One for the woofer, the second for the mid-range.
I can imagine some interference/nulls/distortions with the two ports interacting.
With the hyper accuracy of these full-rangers...one could make a superior system......with the voicing of the Mids being the best possible.
__________________________________________________ ___Rick.......
Old 15th November 2012, 08:41 PM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
wide band midrange
To get the kind of efficiencies specified FF165 is closer.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th November 2012, 10:24 PM   #9
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
If he is looking at 200 Hz XO, why would he use a port? Sounds to me like sealed box is the way to go. Or is there something here that I don't know?
Cheers, Jim
A day without music is like a day without food.
Old 16th November 2012, 02:01 AM   #10
moray james is offline moray james  Canada
lots of good stuff here. have you considered a dynamic in a large straight horn?
Best regards Moray James.
Inlow Sound Products - The Paper Horn by Inlow Sound
moray james
wide band midrangeHide this!Advertise here!
Krohn-Hite wide band amplifier Model 7602M anushaas Equipment & Tools 1 8th March 2012 07:10 PM
Selling new 3" wide band drivers markaudio Swap Meet 1 28th February 2010 02:21 AM
Selling new 2-1/2" wide band drivers markaudio Swap Meet 1 28th February 2010 02:19 AM
Wide-band Dipole Project DougL Multi-Way 12 2nd December 2008 04:56 PM
Wide band Common mode chokes by Murata Dr.H Digital Source 2 3rd July 2003 03:29 PM
