diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Dynamat/fatmat for a cab vibro damping (http://www.diyaudio.com/forums/multi-way/223640-dynamat-fatmat-cab-vibro-damping.html)
PKI 15th November 2012 03:05 PM
I see that Troels uses bitumen sheets for his cabs to make them heavier and decrease walls vibration. Can I use dynamat or fatmat for the same purpose?
I am worrying about the aluminum layer on them(sound reflection, conductor etc). Or it is not even necessary and just felt or/and polyester are enough?
weltersys 15th November 2012 03:44 PM
Rather than damping vibration by adding mass, why not eliminate vibration using bracing?
PKI 15th November 2012 03:46 PM
I was thinking about both, actually :-)
weltersys 15th November 2012 03:48 PM
Brace first, if not dead enough, brace some more ;^).
PKI 15th November 2012 03:51 PM
And how can you say when: "dead enough"? :-)
weltersys 15th November 2012 03:57 PM
When I hit the cabinet with my fist or a rubber mallet and hear no ringing, "dead enough".
Bare 15th November 2012 04:26 PM
In the past some have advocated using Concrete Tile backer board as 'mass loading' to enclosure interiors :rolleyes:
For a while the slapping on of Ice & Water Shield ( Similar and a Small fraction of Dynamat price and often of Much better quality, also a Very large selection of available types) from a 'Real' Construction supply store (not Home Depot) May not help (my opinion) but also won't hurt, not even your wallet if you avoid the usurious Audio Weenie market's Dynamat prices, like any reasonable Human should.
There are also genuine arguements for resonant enclosures.. Nothing is ever a straightforward answer :-)
Copyright 1999-2017 diyAudio
