Small Thor -Reloaded -First build - Page 3 - diyAudio
Old 18th November 2012, 03:09 AM   #21
Thank you both again
I feel a little like a Stranger in a Strange land. Have not heard the word grokked in a while
Ron my ears are crappy too. I will probably need to put the new crossover in the right speaker and leave the old one in the left to compensate. : (
Unless I am completely missing the point it seems in reading that the plywood raises the resonances and mdf lowers it. will using a 3/4 mdf front baffle backed up with 5/8 plywood negate the effect of the rest of the speaker being built out of plywood? I am sure you can get good results with ply and good results with mdf. It would be just my luck that using both will turn these into Bose.
thanks again
Ben
Old 18th November 2012, 03:28 AM   #22
GM is offline GM  United States
GM's Avatar
Originally Posted by 8ntractor View Post
Ron thanks I have already burned thru half a note pad of graph paper.
Maybe this will help: Cut List
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th November 2012, 05:14 AM   #23
Renron is offline Renron  United States
Renron's Avatar
GM,
Cut list is a great program, nice tip.
Grokked? Hum, must be a Canadian thing, not a clue.......
Front baffle with both sounds like a good idea. No problems there as long as you relieve some of the backside for reverse pressure from the movement of the cone..
Don't over think this.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 18th November 2012, 05:26 AM   #24
frugal-phile(tm)
planet10's Avatar
American origins. Robert Heinlein's Stranger in a Strange Land. Required reading.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th November 2012, 05:36 AM   #25
Renron's Avatar
AKA; Rote
Old 18th November 2012, 12:27 PM   #26
GM, Thanks for the cut list it looks like a great program and timely as I am buying more materials monday.
Ron, I do have to stop overthinking it I just want to build the best speakers I can. This hobby is addictive. I am not normally this obsessive but for some reason I am spending way too much time on this.
Robert Heinleins is a science fiction author as wrote Starship Troops. Stanger in a Strange land was his best IMHO.
Fitting on a couple of fronts as we are transplants from the US.
thanks again all
Ben
Old 18th November 2012, 01:16 PM   #27
I mean strange land in the most positive way - black bear momma with 3 cubs walking thru the yard. Mist rising off the Ottawa river. Fox and Wolf frequent visitors occasional moose sightings. One of the most beautiful places ever.
Old 18th November 2012, 03:49 PM   #28
The port in the drawing is at the very bottom of the cabinet in reading many have put the port up 4.5" from the bottom does it matter and which was Scottmoose's intention?
thanks
Ben
Old 18th November 2012, 06:17 PM   #29
Dave what did you mean on the drawing note 6 that diagonal is even better?
thanks
Ben
Old 18th November 2012, 07:12 PM   #30
frugal-phile(tm)
planet10's Avatar
We have mostly deer, occasional bear & cougar.
dave
Problem with Small Thor build vikingshill Multi-Way 10 20th May 2011 02:45 PM
Thiele-Small reloaded with LTspiceIV steph_tsf Solid State 12 9th May 2010 08:59 AM
Small SEAS Thor Equipment Pairing (Help) c5z06 Multi-Way 2 28th January 2010 11:27 PM
Curved Small Thor Build Renron Multi-Way 102 20th January 2008 01:03 AM
Here's another Thor (Small) greenie512 Multi-Way 26 3rd September 2007 03:56 AM
Copyright 1999-2017 diyAudio
