Small Thor -Reloaded -First build - Page 10 - diyAudio
Old 9th December 2012, 09:59 PM   #91
Thanks Ron
Here are a few more pics - using every clamp I have - my workshop- the semi finished speakers. I need to fix the damaged speaker you can hear a little rattle in the top woofer. I cannot finish the speakers now until spring as the weather in my workshop is a little damp. I have not had time to listen critically Just finished. Learned I suck at soldering
Old 10th December 2012, 03:20 PM   #92
Renron is offline Renron  United States
Renron's Avatar
It will be good to have them inside and "dry out" over the winter. They should equalize nicely and be ready for the finish come spring. Go easy on the volume knob until you fix that buzzing driver. My speakers sound best ~50% or higher.
Yours was a very quick build, I hope you enjoy them as much as "We" do.
I don't recall if your drivers were "New" or "Used", if new expect ~50 hours of break in time before they start to sound good. Patience Luke..........
Dave (P10); Do you have any opinions on the felt around the tweeters? Curious that.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 10th December 2012, 09:36 PM   #93
frugal-phile(tm)
planet10's Avatar
In theory it should help. If thou they are the hard-ish felt furniture pads you can buy, i'd remove them and replace with something soft & lower density.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th December 2012, 09:56 PM   #94
Renron's Avatar
Thanks Dave,
i can always count on you for answers.
Ron
Old 11th December 2012, 06:13 PM   #95
Hello
I just wanted to say thanks for all of your help on these. The work that was not getting done while I build the speakers has piled up (along with the snow) so I have not had much time lately. The speakers are used drivers and actually sound very very good. The clarity, imaging and soundstage are all very good. They best the 802M in many ways. I have not cranked them at all yet. I have not measured them or even moved them to try to improve the sound. Even at very quiet levels I am able to hear detail that I never heard before. I was wondering about the felt it does not look like anything special I don't like the way it looks but I will not remove it until I have some time to really study the sound and after the driver is replaced. I am still waiting to see if the post will pay for part of it. The very slight buzz in the driver was only when I ran a 40hz signal to that speaker. It is not present when listening to music or even with 100hz signal. I do know one thing for sure I will never buy commercial speakers again. These sound as good as any speakers I have heard at least to my suspect ears.
Again I would like to thank Ron, Dave and GM for all of your help and support. and scottmoose for the cabinet work. I will keep you posted as I have time to fine tune them.
Thanks again
Ben
Ben
Old 11th December 2012, 06:48 PM   #96
Just spent a little more time listening this time to Rock and Pop (up until now I have been listening to classical). I just have to say these speakers are awesome. I am so impressed by the sound natural and realistic. B&W who? These speaker Rock.
thanks again guys
I won't sign my name on this one as apparently I did twice last time.
Old 13th December 2012, 10:09 AM   #97
Is there a right and a left speakers? does the small side of the brace go inside or outside or does it not matter?
Old 13th December 2012, 03:22 PM   #98
Renron's Avatar
Same difference. L&R.
Glad you like them. Welcome to the "Club".
Old 13th December 2012, 10:12 PM   #99
thanks Ron
the speakers are great. Best my wife and I have ever heard. the cabinets were time consuming and I would do things a little different next time but the speakers are great. I used screws for the drivers and the bottom of the speakers but will change to bolts. I am not sure about the crossover. Right now we are pretty happy with what we have. Is the crossover change a very large improvement. the bass seems very good. the other questions I have is should the tweeter have reversed polarity or is that only on the upgraded crossover.
How important is it to make the cabinet air tight. the base is not air tight. the drivers are not gasketed so are not air tight. are these thing important or not really? what about spikes did you notice a difference with spikes.? when we move the speaker upstairs the spikes will have to be on the little pads as we have hardwood floors.
thanks
Ben
Old 14th December 2012, 04:57 PM   #100
Renron's Avatar
thanks
Ben
Ben,
I felt that the new XOs did make a significant difference in the sound quality, however, it did knock down the total volume Db by a noticeable amount. What used to be a comfortable listening volume at 9:00 is now 11:00. Still plenty of volume left thou, so it's not a problem. My amp is an F5, not known for being a powerhouse of an amp.
Try changing the tweeter polarity, if you like it, good, if not it's easy to change back.
The cabinet is not air tight, if you built it correctly it has a huge hole in it. Right? It should be sealed except for the port, think of the air inside the speaker box as compressing like a spring to push back against the backside of the midwoofer drivers. If the bottom of your speaker boxes is open or not sealed well the Transmission Line design won't function properly. Important.
I didn't use a gasket behind my drivers either. No problems with mine. Instead of screws, I used 8/32 x 3/4" allen head bolts, they sit flush and blend well with the basket color. Plus there is MUCH less change of damage to the drivers with an allen key than a phillips screwdriver...... ouch.
I don't use spikes so I can't help you out there. I've heard that it improves the quickness of the bass. ? IDK. I have mine on carpet and at some point will put them on a 1" thick slab of granite w/ spikes. Just have not felt the need to try that out yet.
Get used to your speakers before you play with the XOs, then tweak them and see if you like it better, you'll learn and it's fun.
I thought it was funny that you mentioned it took a long time to build your speakers....., mine took all summer.
Ron
Problem with Small Thor build vikingshill Multi-Way 10 20th May 2011 02:45 PM
Thiele-Small reloaded with LTspiceIV steph_tsf Solid State 12 9th May 2010 08:59 AM
Small SEAS Thor Equipment Pairing (Help) c5z06 Multi-Way 2 28th January 2010 11:27 PM
Curved Small Thor Build Renron Multi-Way 102 20th January 2008 01:03 AM
Here's another Thor (Small) greenie512 Multi-Way 26 3rd September 2007 03:56 AM
Copyright 1999-2017 diyAudio
