Some Ambiguities, Zaph ZRT - Page 2 - diyAudio
Old 15th November 2012, 08:31 AM   #11
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
.5 woofer works just fine in same chamber as major. I have read an article about experiments of this, perhaps it was Zaph himself? Two-in-one may actually help to kill standing waves in the box, that happens in rooms with two subs!
AINOgradient speaker project
Old 15th November 2012, 01:44 PM   #12
Juhazi's Avatar
Yes it's Zaph, here's the link
Zaph|Audio
Old 15th November 2012, 02:05 PM   #13
Creddy is offline Creddy  Sweden
Alright, sounds good in that matter : ) i have read some at troelsgravesen.dk
that the volume important for the interpretation of the sound, larger chamber
gives a more "muddier" sound and smaller more "tight".
As is have said earlier
I think that it can have negative effect to the sound, because when
the .5 woofer are not “playing”, the other woofer is “playing” in a twice as big
chamber that it is designed for. And therefore maybe making it more
muddier sounding, i want the sound to be fast and tight. ;D
The question is if the muddy/tight phenomenon is showing in measuring-graphs and calculations?
Thanks xjr100 and giralfino for the crossover tips, I'm really grateful for the help!
Old 15th November 2012, 04:13 PM   #14
xjr100 is offline xjr100  Europe
Originally Posted by xjr100 View Post
L2, 0.25mH 0.15Ohm
You can use CFC16-0,27, it is 0.16Ohm - it will add about +0.3db in area at 1.5 to 2.5db, what I think is not bad
Some typing mistakes here: meant +0.3dB in 1.5 to 2.5kHz
You can get some crossover design tool and play there with schematics and filter gain and see what the changes could be if you change the values. But changes on the graph is only part - another very importnat part is how it plays. Basically there some guides what resulting response should be (very typical is 20-20K +-3dB), but depending on what components you use (caps, coils, drivers), those "+" and "-" must be in different places according to listening tests.
Auricap XO, Mundorf, Jantzen capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Old 15th November 2012, 04:38 PM   #15
Originally Posted by Creddy View Post
I think that it can have negative effect to the sound, because whenthe .5 woofer are not “playing”, the other woofer is “playing” in a twice as bigchamber that it is designed for. And therefore maybe making it more
As I posted with the response plots above, there is no point at which one woofer is "playing" and the other is not.
Old 15th November 2012, 05:14 PM   #16
Yeah true, it never stops playing(thought that it was a much steeper roll off on the .5 woofer)
but at around 600 hz there is about 8 dB difference between the woofers,
so the main woofer will loose pressure and act like it will play in a bigger chamber?
Do you think it is audible?
Great if not, then it will be a bit easier to build ;D
Zaph ZRT - Help for variation cyberlancer Multi-Way 15 8th October 2012 07:49 AM
Anyone have Zaph ZRT Revelators in New York City? bfs21 Multi-Way 1 23rd April 2012 03:52 AM
ZAPH ZRT 2-way sealed cabinet option homebuilder Multi-Way 13 9th February 2012 12:19 PM
Zaph ZRT Tweeter Placement ciagon Multi-Way 0 14th March 2010 06:25 AM
Zaph ZRT -vs- ProAc 2.5 clone jallenbass Multi-Way 4 23rd August 2008 02:15 AM
Copyright ©1999-2017 diyAudio
