Why no DIY Tektons/10in. 2ways? - Page 2 - diyAudio
Old 13th November 2012, 05:44 PM   #11
some of tekton speakers dont even have a crossover. with standard eminence alpha or beta. i remember one with a 10" beta wizzercone, the dome tweeter was even smaller than a 1" from what i could see. a_tewinkel has a point
Old 13th November 2012, 06:18 PM   #12
picowallspeaker's Avatar
I have at stable use a speaker with a 10" and a very little fullrange 2" with
7" waveguide ( ex-speaker ). The FR is very similar to the concave Tang Band,
it's made by Monacor .
The simple series crossover helps in stopping the woofer emitting from 1000 Hz
and the FR from not going over excursion
Old 13th November 2012, 06:49 PM   #13
DougL is offline DougL  United States
I believe the Dynaco A25 was a 10" 2 way.
Seas made the 10" until a couple of years ago IIRC.
Seems to me you need a wide range 10" and a tweeter that can cross low.
Good luck with your project.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 13th November 2012, 08:54 PM   #14
Pallas is offline Pallas  Pakistan
Originally Posted by wushuliu View Post
Tekton speakers have been taking off the past 2 years and are getting more and more acclaim; yet from what I've read and seen they are ultimately (well-designed) 8 to 10in. 2ways. Searching the forum I see very little mention about them and even less discussion on 10in 2ways with dome tweeters. Why so little interest? Seems like a great compromise for low watt amp freaks and those not really interested in pure full range.
A great compromise, unless one cares about how the music sounds.
Then it's just compromised.
Serious Audio Blog
Old 13th November 2012, 09:05 PM   #15
vinylkid58's Avatar
Or a wide range with a tweeter that can cross high, like a Fostex FF225wk + FT17h.
jeff
Old 13th November 2012, 09:20 PM   #16
I use a Monacor SPX-20 , similar to the TB W2-784 SG, although the first choice was a phase plug equipped one such as the TB W2-803 because of the wave guide I intended to use to have some sensitivity gain at the crossover region...but the bumped surround introduces some irregularities .
So ,Monacor SPX-20 !
Old 13th November 2012, 09:38 PM   #17
I am not talking about Econowaves though, I am talking about designs like Tekton's... at any rate it's clear it's something that just hasn't been tried here or heard really (only took 2 posts before thread derailed into CD...) so I'll take my inquiries elsewhere.
I designed these before I heard about the Tektons.
System Pictures & Description
Eminence 10" pro woofer, Ciare horn tweeter.
Excellent loudspeaker, precisely balanced. High sensitivity, 96 - 97dB.
I posted the design, but not much interest. Hearing would be believing though.
Old 13th November 2012, 09:55 PM   #18
blakkshepeaudio's Avatar
Which Eminence are you using? Just curious as I recently made some 12" and horn foldback boxes for my Son's band and was a bit shocked at how good they sounded.
Would be interested to try a high sensitivity 10" and horn, and Eminence drivers are available at reasonable prices here in OZ.
blakktie
Old 13th November 2012, 10:05 PM   #19
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
I use a pair of Zu Essence speakers. These 10 inch full ranger/ribbon tweeter speakers have been out for several years, and build somewhat on the Zu Druids, which have been around for a long time.
This configuration, done sans crossover, has been around for a long time. Many, very differing opinions on how they sound.
Guess I am about as old as the folks that voiced them as they sound pretty good to me, and work well with my tubed PP amps. Looking to make a 300b amp and try the SET route next.
If I do anything different with speakers, it will be a GPA 604 based coax speaker.
Old 13th November 2012, 10:09 PM   #20
wushuliu's Avatar
But not all of the Tektons are like that. I have read that the Lores have lower crossover and the one pictured in my first post has to have a low xo as well.
A new 10in subwoofer is born !!! dannyjmf Subwoofers 0 30th January 2012 04:05 PM
WTB One Dynaco A25 Scan Speak 10in Driver Pyre Swap Meet 0 21st August 2008 03:47 PM
goodmans 8in and 10in twin axioms - what do i do? jacojnr Full Range 4 24th May 2006 08:09 PM
looking for inefficient thin profile 2ways smak Car Audio 7 20th September 2005 08:35 PM
Convert existing 2ways into ML TL? GuyPanico Multi-Way 2 27th April 2005 01:47 AM
Copyright 1999-2017 diyAudio
