Why no DIY Tektons/10in. 2ways? Why no DIY Tektons/10in. 2ways? - diyAudio
Old 13th November 2012, 02:21 AM   #1
wushuliu is offline wushuliu  United States
wushuliu's Avatar
Default Why no DIY Tektons/10in. 2ways?
Tekton speakers have been taking off the past 2 years and are getting more and more acclaim; yet from what I've read and seen they are ultimately (well-designed) 8 to 10in. 2ways. Searching the forum I see very little mention about them and even less discussion on 10in 2ways with dome tweeters. Why so little interest? Seems like a great compromise for low watt amp freaks and those not really interested in pure full range.
Old 13th November 2012, 07:32 AM   #2
wushuliu's Avatar
Well, guess that answers that.
Old 13th November 2012, 08:53 AM   #3
a_tewinkel is offline a_tewinkel  Netherlands
The dispersion characteristics will be rubbish with such a design, especially since a 22 mm tweeter is used. Crossover is probably 2500 Hz or higher, which is at least about an octave too high for a 10" unit.
All sorts of speakers get good reviews by the way. In this case the fancy Excel woofer probably helps.
Old 13th November 2012, 02:47 PM   #4
dumptruck is offline dumptruck  United States
I think a CD waveguide really makes more sense for a 10" 2-way, if you're not bound by a "NO HORNS" sales pitch.
Old 13th November 2012, 03:32 PM   #5
von Ah is offline von Ah  United States
von Ah's Avatar
The Econowave approach certainly has a great following, with many using 10" woofers and 1" compression drivers crossed ~ 1.6 kHz. I really like the pair I put together 3 years ago. Maybe horn-loaded domes could get a similarly lower crossover point...
Old 13th November 2012, 03:43 PM   #6
~1.6kHz is for matching a 90 waveguide to a 12". A 10" would be a little higher at 90.
Old 13th November 2012, 03:56 PM   #7
von Ah's Avatar
I forgot the details, it's been so long... 1.6k just stuck in my head. Also I don't remember if that's acoustic/electric... Regardless, I do know it was designed specifically for the Selenium D220ti and a particular waveguide.
Old 13th November 2012, 04:27 PM   #8
wushuliu's Avatar
I am not talking about Econowaves though, I am talking about designs like Tekton's... at any rate it's clear it's something that just hasn't been tried here or heard really (only took 2 posts before thread derailed into CD...) so I'll take my inquiries elsewhere.
Old 13th November 2012, 04:34 PM   #9
If you want to try it, the parts cost isn't bad and it would be easy to turn into something else if you didn't like it. You'd need measurements and simulation to do the required woofer wrangling, unless you're some kind of wizard . They might be mass-loading some of those woofers, as well.
Old 13th November 2012, 04:36 PM   #10
wushuliu's Avatar
Yeah it's something I'll pursue down the road. Just wanted to see if there was any previous feedback.
Why no DIY Tektons/10in. 2ways?Hide this!Advertise here!
A new 10in subwoofer is born !!! dannyjmf Subwoofers 0 30th January 2012 03:05 PM
WTB One Dynaco A25 Scan Speak 10in Driver Pyre Swap Meet 0 21st August 2008 02:47 PM
goodmans 8in and 10in twin axioms - what do i do? jacojnr Full Range 4 24th May 2006 07:09 PM
looking for inefficient thin profile 2ways smak Car Audio 7 20th September 2005 07:35 PM
Convert existing 2ways into ML TL? GuyPanico Multi-Way 2 27th April 2005 12:47 AM
Copyright 1999-2017 diyAudio
