New Linkwitz "LX521" speakers.. - Page 51 - diyAudio
Old 10th January 2013, 11:26 PM   #501
ScottG is offline ScottG  United States
Originally Posted by cport View Post
There is a clarity and truthfulness to the midrange in the LX521 (long my pet peeve with the ORION, which improved with each X'over iteration) that is so natural and right that it is immediately clear we are dealing with a different caliber of transducer. Imaging specificity and micro-dynamics in the LX521 is significantly improved (high WOW factor) over the ORION -- hard to believe, but true.
Actually it's not that hard to believe.
Moving to a smaller diameter lower mass driver for the mids does this all the time.
4" driver with 4.5 grams of mms = better detail.
It's also in the range where it isn't "riding" the suspension or is otherwise overly damped. It would be even more detailed with a good foam surround and/or with greater efficiency.
Imagine what a design would be like with a similar low-mass small sd driver operated as a radial (..like the Pluto).
Zaph has some "companion" drivers to the fullrange that SL uses measured on his blog:
Zaph|Audio
Bearing in mind what I've stated above - consider what it would be like with Vifa TC7FD00-04 posted just below those drivers..
perspective is everything
Old 10th January 2013, 11:45 PM   #502
gainphile's Avatar
I spray painted the upper baffles with the following:
1 coat Sealer [1lbs Shellac] (Brushed/Wiped "flooded' on)
[sand 220/320/600 Grit smooth]
2 coats RUSTOLIUM grey primer
[sand 320/600 Grit smooth]
3 coats RUSTOLIUM "SAFETY RED" Enamel
[sand 600 Grit smooth]
3 coats Clear Laquer
[sand 600 Grit smooth first two coats -- allow 24 dry time between coats]
-- Charles
Thanks !! That sound like a real work of love and it shows !
http://gainphile.blogspot.com
Old 11th January 2013, 08:36 AM   #503
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Sorry, I just can't resist the temptation...
Siegfried's Pluto - Fiat 500 Topolino
[IMG]Click the image to open in full size.[/IMG]
AINOgradient speaker project
Old 11th January 2013, 09:35 AM   #504
lolo is offline lolo  France
lolo's Avatar
now, THAT's a car!
let's see what you come up with for the Phoenix, the mother of all designs.
Old 11th January 2013, 10:24 AM   #505
Juhazi's Avatar
lolo, too easy - naturally the mother of Fiats
Phoenix - Fiat 3½HP
Old 11th January 2013, 10:41 AM   #506
john k...'s Avatar
You're setting me up!
I see that, and I think what it could be is this:
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 11th January 2013, 10:58 AM   #507
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Anything with wheelie bars is bound to be fun. I keep waiting to see a subwoofer with wheelie bars O_O
Old 11th January 2013, 11:31 AM   #508
lolo's Avatar
oh my lord.. how can one transform such a cute and classy car as the Topolino (a lady killer!) into such a beer fed monster!!! (just try to get a chick with that...bonne chance )
it's a bit like...
Uploaded with ImageShack.us
vs...
Old 11th January 2013, 12:52 PM   #509
john k...'s Avatar
I don't think you understand American culture.
Old 11th January 2013, 01:18 PM   #510
lolo's Avatar
maybe not.. but it's that all you've got left over the pond?
"Reverse" Linkwitz Transform Relaxin Analog Line Level 9 23rd August 2012 02:19 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
Linkwitz "Transform" Circuit Help Shike Solid State 10 5th April 2008 11:44 PM
Copyright ©1999-2017 diyAudio
