New Linkwitz "LX521" speakers.. New Linkwitz "LX521" speakers.. - Page 18 - diyAudio
Old 18th November 2012, 03:07 PM   #171
dewardh is offline dewardh  United States
Originally Posted by Melo theory View Post
we both understand that traditional stereophonics is the biggest hindrance in image reproduction.
It's like "democracy" that way . . . the worst possible system except for everything else . . .
If what you're looking for is presentation of totally synthetic acoustic "images" (as with movie soundtracks) then multi-channel-in-an-anechoic-environment is entirely plausible, and practical to implement, too, at least in theaters. On the other hand if you're trying to reproduce a symphony orchestra in your "living room" multi-channel introduces a whole raft of problems, from the beginning of the signal chain (where are you going to place your microphones to capture the correct "image" and perspective?) to the end (what are you going to do about the unavoidable reflections in that "normal", or even remotely acceptable to most people, listening environment?). Not to mention the inevitable "where am I supposed to put all those loudspeakers?" questions, and "how will it sound mixed down to ear-buds/headphones?".
Old 18th November 2012, 03:16 PM   #172
Melo theory is offline Melo theory  United States
Melo theory's Avatar
I'm not talking about multichannel per se......
I'm talking about Ambiophonics, which is what I prefer.
Others prefer LRC matrix wiring. Or flooders for a more diffuse field.
I LIKE YOU
Old 18th November 2012, 07:35 PM   #173
ScottG is offline ScottG  United States
Originally Posted by markus76 View Post
How could wide dispersion be a solution? Having a center speaker appears to be the only solution.
It's not just wide dispersion, it's also the dispersion angle in relation to the listener's head.
Basically the higher freq. section of the loudspeaker needs to be placed closer together for the left channel to provide the right amount of intensity to the right ear (and right channel to left ear).
In this sense then "center" (as a speaker location) is every bit as important. HOWEVER absolute center is counter productive in this respect - extending too much intensity to L(ear) as opposed to R and R as opposed to L (..absolute center provides equal pressure to L & R). Absolute center tends to "bunch" images toward the center UNLESS it's a well-done multi-channel recording with multi-channel playback.
Unfortunately angle also plays a part in sound-field "expansion", where it's advantageous to hear an angle that is closer to 75 degrees (from the listener's center), with a resulting increase in intensity to that near ear.
This is why reviewers are always describing reproduction "image" (or a "vivid") nature vs. "sound stage" with a resulting diffuse image and poorer center localization (..or program material with higher freq. content "sticking to" the loudspeaker or near it).
I'd also note that the paper Elias linked to isn't about room contribution at all, only direct sound. Basically it's assuming a relatively fixed stereo triangle angle for speakers with an omni nature below about 1200 Hz - essentially arguing that only at those lower freq.s will channel balance (channel intensity difference) correctly "vector" images (or position them properly.. at least horizontally). Again though, it's horizontal polar dependent (for the loudspeaker), it's freq. dependent (for the loudspeaker's reproduction/source material), and it's angle (and/or loudspeaker "spread") dependent in relation to the listener's head.
Getting back to the LX521, you can for example: Increase loudspeaker spread to achieve greater apparent channel seperation at lower freq.s.. and/or "toe-out" the loudspeakers for a similar effect (because of the slight loss in pressure off-axis due to the dipolar design). The problem is that you'll end up doing the same at higher freq.s..
Given this design, the recommendation would be to have the upper mid and tweeter with horizontal adjustment capability, so you could angle "in" the upper freq.s while having a fair bit of "toe-out" for the lower mid and bass section. Additionally, you would want a slightly closer seated position than SL recommends, and as a result a somewhat closer "spread" between the loudspeakers.
perspective is everything
Old 18th November 2012, 09:10 PM   #174
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by Ed LaFontaine View Post
Elias, Does a waveguide dome tweeter on the front (closer to constant directivity) and a flat baffle dome tweeter on the back (with the "desirable" diffraction effects) approximate a solution to what you describe?
I think it depends on the delay of the front wall reflections. I'm assuming the front wall is reflective. And talking about high freqs only.
The key to success is to have decorrelated reflections at the listening position, where the decorrelation distance is just little bit over the interaural distance, few ms maximum. If reflection delay is too long, they cannot fuzz the direct sound enough.
Of course this is a rudimentary method, but seems to be obligatory due to the lack of better system level options than the 2 speaker stereo triangle offers.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 18th November 2012, 10:18 PM   #175
markus76 is offline markus76  Germany
Banned
We all have something called HRTF!
Yes we do but what makes you so sure HRTF would be such a dominating issue in terms of horizontal localization? The paper I've linked earlier provides a pretty good overview of localization cues.
Old 18th November 2012, 10:55 PM   #176
Well markus...people believe different things.
My beliefs come from my experience, not white papers and other people's theories.
I LIKE YOU
Old 18th November 2012, 10:55 PM   #177
Banned
Originally Posted by Simon Rambert View Post
In terms of attention-attracting tweeters maybe Uli Brüggemann's FLOW could be a part of the solution?
I don't think this is a good idea what Uli is doing there. It targets a production problem and not a reproduction problem.
It also doesn't really fit what the Bennett paper describes.
Old 18th November 2012, 11:00 PM   #178
Banned
You make it sound like I wouldn't have any experience and would base my opinion only on other people's beliefs and white papers. Rest assured that I do have listening experience with virtually all the mentioned reproduction techniques.
I believe that you know that Ambiophonics doesn't solve the HRTF issue.
Old 18th November 2012, 11:30 PM   #179
I didn't mean to sound like that, but a lot of people here are always mentioning literature that others publish to make their points. We have to remember that the people that write those papers are people with opinions just like us....... Toole, Linkwitz, D'appalito, Haas, Glasgal.... and the rest of them. I think referring to these same old theories are whats keeping us talking about the same crap. So I say from my experience Ambiophonics is best. I have listen to stereo, multichannel, mono, pro logic matrixing, OSD.
I don't know of anything else that comes closer than ambiophonics in appealing to HRTF, regarding 2 channel sources. Of course it doesn't solve the pinna problem, but it puts it pinna cues in a better location.
We all know that the best way to realism is perfect wave propagation as found in high order ambisonics, but we have to keep it in context of 2 channel recordings.
Actually, we might all be without our loudspeaker obsessions soon if Binaural audio keeps gaining traction!
I LIKE YOU
Old 19th November 2012, 12:41 AM   #180
Soundtrackmixer is offline Soundtrackmixer  United States
No dubbing stage(where soundtracks are created), and no movie theater is Anechoic in nature. Their acoustics are just better defined by standards from THX and SMPTE.
We have been doing multichannel recordings for so long now, the problem you mention here are completely irrelevant. We know where to place the microphones in a acoustical environment - we plan for that in pre-production. We also have plenty of rehearsal time with an orchestra before the recording is ever done. I am also pretty familar with the recording venue based on the rehearsal we have done. The standards for speaker placement, subwoofer placement, and calibration of the monitoring system have also been firmly established.(see ITU -R BS-775-1)
You cannot account for the individual listening space, and all of the acoustic issues that come with them. You can only create the best sounding multichannel mix, and let the chips fall where they may in the home environment.
Where to put all those speakers is information you can easily gather on the internet. It is not hocus pocus, or hard to obtain information. Both Dolby and DTS have primers on 5.1 and 7.1 channel speaker placement. DTS even has a primer on where to put a ceiling speaker as well to blend in with a 7.1 setup.
There are very good 5.1/7.1 to 2.0 mixdown algorithms out there, and in the film industry we have been using them in conjunction with Dolby Digital since it was introduced in the home back in 1994. DTS also has a great mixdown algorithm that comes with the DTS encoder. The few movies that I have used both of the algorithms were monitored after the encoder mixdowned the multichannel to stereo mix.
New Linkwitz "LX521" speakers..Hide this!Advertise here!
"Reverse" Linkwitz Transform Relaxin Analog Line Level 9 23rd August 2012 02:19 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
Linkwitz "Transform" Circuit Help Shike Solid State 10 5th April 2008 11:44 PM
Copyright ©1999-2017 diyAudio
