Open Baffle natural roll off? - Page 3 - diyAudio
Old 13th November 2012, 01:06 PM   #21
5th element's Avatar
What he means is that in the dipole, without a filter in place, as frequency decreases, excursion goes up and ends up being destructive. Even if you were after say a 1st order roll off at 500Hz and your baffle was sized to give you just that, you would still need a suitably steep filter to keep excursion either constant with decreasing frequency, or decreasing with decreasing frequency (steeper filter).
Old 13th November 2012, 01:14 PM   #22
Yes that makes sense, I realized I made a mistake in amusing a 12dB/octave instead of 6dB/octave natural roll off.
I have now implemented a LR4 at 120hz and dipole correction shelf.
I just hope that one Peerless XLS 830452 in each baffle will suffice?
I have cut all the MDF ready to make the H-frame, just need to route the driver cut out in the baffle and glue together.
Old 13th November 2012, 03:01 PM   #23
I used 1 xls per channel for a long time before upgrading to a push-pull pair. One pair is fine unless you're wanting to really listen quite loud.
I am sure you are aware of the ebay buyer who routinely sells 452s for about 90 each, should you feel the need to double up. The gains are worth it imo, of going push-pull, but by no means necessary unless you really need the extra output.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 13th November 2012, 06:51 PM   #24
Pano is offline Pano  United States
Pano's Avatar
I'm not sure what you'll end up with using a 10" woofer and 12" baffle, that seems pretty small to me - for OB. But most of the OBs I've built or worked with end up with about a 9dB/octave roll-off. Not sure why, but that's how they measure. At least down to Fs.
Will be very interested to see what results you get.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 13th November 2012, 07:09 PM   #25
Will soon see, I may end up buying another pair of XLS 452s.
Oh and BTW I did buy my pair from ebay for 75 each iirc.
Old 13th November 2012, 07:32 PM   #26
Just thought I would post a couple of pics of my progress.
I have yet to build the H-frame woofer so my BK subwoofer is supplying the bass for now, it also uses a Peerless XLS woofer so will look similar to the photos when complete.
The design is also a copy of Gainphile's S16 speaker.
Old 13th November 2012, 07:40 PM   #27
Pano's Avatar
Ah, cool. Now I understand the sub is boxed. Didn't get that before the photo.
Old 14th November 2012, 10:52 AM   #28
norman bates's Avatar
but you're probably peaking around 1khz and rolling off b4 you make it to the sub.
Old 15th November 2012, 08:35 AM   #29
Hi, just jumping in my front are Ripols , Peerless the classic one with correction network, Manger, x-over mini DSP. Going 7.1 I like to have the rest open baffle. I could easily build another ripol as needed but I don't think so. In this setup the zurround speakers can roll off naturally I do guess
Old 4th February 2013, 12:49 PM   #30
Well I managed to get the H-frames built, had some 18mm MDF cut to size at my local garden centre, spent two hours this morning routing rebates and the driver cutouts and then gluing it all together, used a ratchet strap to hold it all together while it dries.
Woodwork is not my strong point!
The reason why open baffle have a bass roll-off aarvin2 Full Range 25 18th March 2015 11:30 PM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
FR125s no baffle roll off Foxx510 Full Range 2 3rd February 2008 09:54 PM
Natural roll-off or cross-over: what's best? Klimon Full Range 2 6th February 2006 06:41 PM
Help me find a woofer that has a natural roll-off and may not need a x-over... Greggo Multi-Way 23 2nd April 2004 03:18 PM
Copyright 1999-2017 diyAudio
