Combining xover of 2nd order & 4 order - diyAudio
Old 12th November 2012, 10:10 AM   #1
Default Combining xover of 2nd order & 4 order
Dear Folks,
Need help and advice on the following question:
(1) For the attached diagram (Crossover of JBL S2600), for the tweeter part, Does it belong to 3rd order or 4 order ? (because the last L to the ground has one cap in series, which is different from the normal connection learned in Internet)
(2) If the tweeter xover belong to 4 order, then if I intend to add a supertweeter with 2nd order xover. Since 2nd order is 180 degree phase reversed, do I need to connect the supertweeter with reversed polarity ? (provided that the fourth order has no phase shift =0 degree)
Please help.
Eric
Old 12th November 2012, 11:44 AM   #2
jerome69's Avatar
Dear Eric,
Both are second order electric. but the tweeter have corrections : a R//C to increase high frequency level and a LC for attenuate a resonance.
Acoustically it is an other story.
I think, you should go to an other design.
Regards.
Old 12th November 2012, 02:11 PM   #3
Default Super tweeter crossover question
Dear Jerome,
Still have few questions:
(1) If the S2600 tweeter crossover is in 2nd Order. Do I simply use also another 2nd order (say 18000Hz) crossover for the supertweeter while maintaining the same polarity as the S2600 ?
(2) Is it common or not recommended to have 2nd crossover for the tweeter (S2600) while putting my super tweeter by using 3rd order crossover
(3) We always find the polarity switch for the subwoofer but seldom find the polarity switch for the individual super tweeter unit (with built-in crossover, like Tonnoy or JBL type). Does it mean the high freq does not care much about the polarity effect ?
Eric
Old 12th November 2012, 02:23 PM   #4
Michael Chua's Avatar
Any idea why there are two 82 ohm/10w (R1, R2) across the LF. Similarly, the 5.1 ohms (R4) across the HF.
ampslab
Old 12th November 2012, 02:54 PM   #5
diyAudio Member RIP
The order of the x/o (acoustic or electric) does not affect driver phase
in the passband, the actual acoustic slopes effect the phase matching
around the x/o point.
For 2nd order acoustic x/o points the phase for each driver is + and
- 90 degrees, giving a total of 180, so you reverse one drivers phase.
For 4th order acoustic x/o points the phase for each driver is + and -
180 degrees, giving a total of 360, so you connect drivers in phase.
There is no simple answer to the phase of adding a supertweeter,
if you are allowing drivers to overlap rather than crossing over.
rgds, sreten.
Old 12th November 2012, 07:52 PM   #6
jerome69's Avatar
Originally Posted by iceman009 View Post
Dear Jerome,
Eric
Eric see Sreten's Response. I think if you want good treble, use an other design or speaker. To have good treble you should redesign the speaker because to have a good phase, good treble, you should measure the responses.
Honestly, you don't need a super tweeter, this response might not satisfied you
http://www.jblpro.com/pages/pub/components/2426.pdf
Just for flatten impedance peaks
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
2nd order LR series xover formulae PeteMcK Multi-Way 30 9th June 2007 07:27 AM
deceptive perception ? 1st order-2nd order question poldus Multi-Way 4 10th April 2007 11:58 PM
changing x/o from L&R 2nd order to 3d order busterno1 Multi-Way 0 22nd April 2005 10:09 AM
2nd Order Xover question johninCR Multi-Way 7 10th August 2004 08:15 AM
Copyright 1999-2017 diyAudio
