S22 - The latest dipole bandwagon
Old 9th November 2012, 04:02 AM   #1
gainphile is offline gainphile  Australia
gainphile's Avatar
Default S22 - The latest dipole bandwagon
I'm sold to the benefits of maintaining constant dipole directivity to higher frequencies:
So, the same thinking along the lines of the above designs:
The Small MTM would be B3N and DQ25. Woofer will be either W22 or L21.
It should be fun
http://gainphile.blogspot.com
Old 9th November 2012, 04:38 AM   #2
dewardh is offline dewardh  United States
Me too. It's the one significant weakness of my ORION. Got to pay attention to the vertical also, though, so I wonder about MTM. I was quite impressed by the LX521 (which I heard at BurningAmp), but since I already have the dipole woofers and W22 "lower mids" I'll probably just replace the Milleniums with some sort of dipole "two way tweeter" . . . the Milleniums being where ORION's problem is. There are some nice flat and low distortion (and very inexpensive) Tang Band 3" that I like, and I already have some small tweeters that should do, at least for experimenting. The baffle will probably look a lot like the LX521, at least in the first few tries . . .
Old 9th November 2012, 06:47 AM   #3
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
It should be fun
You like the DQ? I don't care for it. The B3N will likely have to be cut fairly high up to keep from overexcursion. I personally feel your woofer choice will outshine the rest of this system.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 9th November 2012, 08:17 AM   #4
jerome69 is offline jerome69  France
jerome69's Avatar
Agreed, keep the small driver in the same vein as the woofer.
The Vifa TC9FD18-08/Vifa TG9FD10-04 could be a good candidate.
But I think you should test the shape of the baffle before doing anything, things are complicated in the high frequency area.
Yes it is a fun project
Old 9th November 2012, 02:10 PM   #5
454Casull is offline 454Casull  Canada
Try running the tweeter baffle-less, e.g. suspend it in a "hole" with a gap at least as wide as some significant fraction of the longest wavelength in its passband. 1/2 wl?
Old 9th November 2012, 02:22 PM   #6
That just makes it omni below a frequency determined by its faceplate diameter, transitioning to beaming above. Not much use if you're trying to match to a dipole . . .
Old 9th November 2012, 04:09 PM   #7
a_tewinkel is offline a_tewinkel  Netherlands
Your first sketch looks promising!
However, I'd opt for something with a more efficiency than the B3N. A 3" driver does not have a lot of power handling and will never be driven anywhere near xmax, since it will have to be crossed over very high. I know someone who used an Omnes BB3.01, which has 87 dB efficiency, without a baffle. 900 Hz was about the minimum crossover frequency he could achieve within thermal limits because of the acoustic short circuit. The B3N only does 81 dB @ 1 W.
How about this or this?
Old 9th November 2012, 04:37 PM   #8
Jack Caldwell is offline Jack Caldwell  United States
Looks like a great project. Having tested and compared directly to the B3N I'll second a previous comment about the Vifa TC9FD18-08, it's probably a much better choice. Higher efficiency, and much cleaner sound, it's a remarkable little driver.
I'm thinking to use them in a time aligned, group delay accurate OB with a di-pole AMT tweeter from Beyma TP150H, with the back removed and using a double CD horn front and back... but if I can get the Beyma to go cross low enough and still preserve the uniform group delay, then I would probably bypass the 3" drivers.
But do think about trying those Vifas!
Commercial Site: www.HologramAcoustics.com
Old 9th November 2012, 05:56 PM   #9
Also look at the Tang Band W3-881 or W3-1053SC . . . both sound better than the B3 (and a lot better than you'd expect for the price).
Old 9th November 2012, 07:39 PM   #10
badman is offline badman  United States
badman's Avatar
True for 'normal' dome tweeters- he may be thinking of a planar or some such?
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
S22 - The latest dipole bandwagonHide this!Advertise here!
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 8 29th March 2015 08:45 AM
How much free air does a dipole line need to stay a dipole? seaspeak Planars & Exotics 0 13th September 2011 04:20 PM
(WW) MMTMM dipole 4 vs 3 way / dipole benefit frequencies? charliemouse Multi-Way 25 7th July 2007 11:19 PM
Latest incarnation of my open baffle/dipole speaker tom1356 Multi-Way 24 22nd May 2004 04:19 PM
The open baffle bandwagon passed by my house... tom1356 Multi-Way 0 30th December 2003 08:46 PM
