Interesting read I found on Lossy Cabinet designs by Harbeth
Old 24th November 2012, 06:18 PM   #81
Baseballbat is offline Baseballbat  Germany
If you decoupled both cabinets properly: yes.
And the bass cabinet must be that stiff that the fundamental resonance is considerably above the crossover region.
Old 25th November 2012, 09:52 AM   #82
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
limono all UK reviewers have to have a pinch of salt added. In the case of Practical HiFi a cart load of NaCl. I remember a group review of tube power amps including a Luxman that performed flawlessly measured well and was very well built. Not recommended as it was not musical or somehing. The UK amp TVA-1, measured badly, hummed and the paint flaked of and to top it of one of the amps cought fire during the test. But as it was "musical" it was recomended buy if the manufacturer could sort out these minor flaws...
I think you bring up and important thing with the rooms and ways of building, when I lived in the US I was surprised at the very flimsy way houses are built.
Old 25th November 2012, 11:25 AM   #83
system7 is offline system7  United Kingdom
system7's Avatar
Indeed, Dr. Boar, it is no coincidence that the smarmy, untrustworthy character in US films is usually a British HiFi reviewer.
The Living Voice Avatar is an interesting loudspeaker more in the Lynn Olson "Ariel" mold, IMO. But a terrific read about it here which makes many good points about a speaker with a bit of magic:
6moons audio reviews: Edward Barker
Back to Harbeth. The Harbeth Compact 7ES-3 is an interesting take on the 8" bass, 1" tweeter idea that gathers some praise and may suit the British upper classes' drawing rooms:
StereoTimes --
I would guess we have said enough about the tiny LS3/5A style Harbeth P3ESR already, but working class people living in tiny British Brick Terrace houses may find them of interest, but probably can't afford them:
6moons audio reviews: Harbeth P3ES
Hope that helps. Clearly not for our American cousin's rooms which are evidently the size of aircraft hangars.
Best Regards from Steve in Portsmouth, UK.
Old 25th November 2012, 12:10 PM   #84
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
wow, thats a lot of nice DIY clones you have collected there
Old 25th November 2012, 12:24 PM   #85
system7's Avatar
Sarcasm, no? I really feel no need to discuss cabinet construction any further since it is already covered for diy purposes:
http://www.diyaudio.com/forums/multi...ml#post3234256
If you want to build something as remotely good as a Harbeth, there are many aspects to consider. Personally, I like Alan Shaw and have no interest in dissecting his genius or secrets. I have the same high regard for Joachim Gerhard.
Now YOU tell ME something interesting.
Old 25th November 2012, 12:47 PM   #86
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Here some experimental and measurement data on different materials:
(Use google translate )
HSI :: Luidspreker kast materialen onderzoek
I once had a link to a german site where you could actually play examples of how the different marerials sound .... but cant find it anymore ....
I think a sandwich approach might give the best of more worlds ...
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 25th November 2012, 12:59 PM   #87
R.I.P.
Originally Posted by system7 View Post
HI, sreten, how did I guess you didn't lay out big bucks for your Spendors?
Such a tightwad!
I bought them building a budget system for someone else and
ended up with them when he moved to Japan. 120 including
good stands for a used pair of Preludes (not bad). System also
had a rechargeable battery powered preamp / mosfet power
amplifier I aquired for him for 60, topped off with a IIX/Rega.
rgds, sreten.
HiFi Choice Best Buy and all that at about 280 at the time.
Detuned the port, inspected the x/o, and left it well alone.
Classic BBC type sound, probably still very nice today.
Monsterously sized magnet on the short coil bass/mid.
The side walls were damped chipboard, as thin as they appear above.
Front was plain 18mm chipboard, the rear plain 12mm ply, I recall.
Basically the BC1 bass/mid, built into a more cost effective speaker.
Old 25th November 2012, 01:04 PM   #88
This thread is turning into the usual over-complication, I'd say.
no problem, its simple
Old 26th November 2012, 07:22 AM   #89
Baldin's Avatar
Found the link to the site where some folks have both measured and recorded the sound of different materials and sandwich combos .... take a look and listen
HAUPT
BR Baldin
Old 26th November 2012, 11:19 AM   #90
speaker dave is offline speaker dave  United States
speaker dave's Avatar
HAUPT
BR Baldin
Great link, thanks.
Note that some have a real audible pitch to them and others are more "tick" than "tonk". The bitumen damped ones are generally good.
These are double cabinets, front and back, so only cabinet radiation is heard.
Much confusion abounds about the Harwood experiments with most audiophiles offended by the thought that ever thicker walls wouldn't be always better.
The way to look at it is that you might be offered your choice of 20 pound cabinets. You could have 20 lbs of solid MDF, no damping. You could have 18 lbs of MDF and 2 lbs of surface damping, or you could have 10 lbs of MDF with 10 lbs of damping. Under those scenarios the 10/10 combo would be best. It would have the lowest level of resonance and the least audible cabinet breakthrough. Harwod even showed that if the choice was a 10 lb cabinet with 10 lbs of damping and a 20 lb cabinet with 10 lbs of damping, that the 10 lb cabinet was probably better, the more massive and rigid cabinet would respond less to the damping.
In the field of architectural acoustics they study this as wall breakthrough from one room to the next. Walls are rated for their TL transmission loss or STC (a single number for loss performance rather than a curve). It is well known that the limp suspended mass is an ideal case for issolation. It has no resonances and rises 6dB per Octave in its TL. This could be a heavy rubber sheet or lead power loaded curtain. Add stifness to the equation and you have a 2nd order system with a resonance somewhere. TL may increase at low frequencies (as well as high frequencies) but some midrange f will exist where the wall is at resonance and transmission will be total.
Damping is the only way to reduce transmission at resonance.
David S
Interesting read I found on Lossy Cabinet designs by HarbethHide this!Advertise here!
TA2024 found a new home (read: case) maurycy Class D 5 9th April 2014 10:33 AM
Interesting Read On 300B's Trout Tubes / Valves 7 26th March 2005 02:47 AM
found an interesting read kaukasion Solid State 0 31st October 2003 12:57 AM
