MLTL for Tannoy DU386? GM?
Old 13th November 2012, 05:55 AM   #21
GM is offline GM  United States
GM's Avatar
Well, it's in the same era as the JBL small BLHs and its folding is conceptually the same, so don't be surprised if it has a similar response to it and the K15 [red trace].
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th November 2012, 06:04 AM   #22
DeonC is offline DeonC  South Africa
DeonC's Avatar
Ouch! That looks like a big peak around 100Hz, and very little below 60Hz. It'll probably sound impressive on rock, but not so good on classical (and I listen to both). Methinks I'll stay with the Berkeley boxes, and see what tweaks I can do to them. Thanks for your time and patience, and all the invaluable information. Very much appreciated.
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 13th November 2012, 06:07 AM   #23
GM's Avatar
Yep, they didn't call them 'kick' bins for nothing.
GM
Old 13th November 2012, 06:16 AM   #24
GM's Avatar
Really nothing you can do with a reflex except tune it higher or lower.
GM
Old 13th November 2012, 08:19 AM   #25
DeonC's Avatar
GM
That, and I'd like to see what the effect of a Karlson cut in the port will have. Luckily the standard port is rectangular, so that will make experimentation easier. What will the effect of 1/4, 1/3, 1/2 and 2/3 length cuts be? As far as I understand, as the length of the cut gets longer, the broader the resonant peak will be. How will that affect the sound? What about broader and slimmer cuts? I will have to try and then find out, won't I?
Enjoy,
Deon
Old 13th November 2012, 02:02 PM   #26
DeonC's Avatar
GM, have a look at the following page:
The measurements on Laurent's hornloaded cabinets
It is a page of someone who built a slightly modified rectangular GRF. According to his measurements, he is close to flat down to 50Hz, and -3dB at 25Hz. What do you think?
Deon
System response w/o horn response:
Response measured at horn mouth:
Simulation according to HornResp:
Old 13th November 2012, 02:19 PM   #27
GM's Avatar
There must be some losses around the driver/internal divider cutout to get such a low average gain BW, indicating that getting this just right might be a tedious endeavor. I've done similar by 'gapping' the driver to the baffle, though a lot quicker/easier of course.
GM
Old 13th November 2012, 02:31 PM   #28
GM's Avatar
Slotting the vent does lower the vent's Q with the trade-off being that it will raise Fp to some mean based on the slot's flare rate. Bottom line is there will be less bass gain BW unless a really large/long vent is used just to get the same amount of bass, same as when using multiple vents of differing lengths like Dr. Geddes has done on BP alignments, though it will be better damped like MLTL loading generates, or just using Olson's vent critical damping routine for that matter and why a combination of the latter two is what I normally use.
Like you say though, only one way to know for sure if it's worth all the extra effort.
GM
MLTL for Tannoy DU386? GM?Hide this!Advertise here!
Altec 416b MLTL, design by GM westend Multi-Way 21 10th October 2014 11:37 PM
Has anyone rear ported the GM MLTL 48 ? batdan Full Range 3 15th December 2009 06:00 PM
GM MLTL fine tuning loninappleton Full Range 35 17th April 2008 07:31 PM
Veneering the JX92S GM MLTL LizardBrain Full Range 10 5th April 2006 09:31 PM
Pictures of GM MLTL-48? PrimaLuna Full Range 28 2nd February 2006 10:01 AM
