Repair speaker
Repair speaker
Old 7th November 2012, 12:33 PM   #1
janbb is offline janbb  Slovakia
Default Repair speaker
I have some slight damage to the speakers and I need advice thus given speaker without damage to undo, no set speaker only drivers
Old 7th November 2012, 12:35 PM   #2
Mooly's Avatar
Repair speaker
More info needed...
Maybe a picture of the damage you are trying to repair
Old 7th November 2012, 05:53 PM   #3
there are
Old 7th November 2012, 06:36 PM   #4
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
What a pity !
the ogival plug I don't care, but the rip is scary!
I don't know if glue would suffice, if the structure is damaged (fragile)
there will happen some nasty resonances that will be audible.
Try some glue ...
Old 7th November 2012, 06:39 PM   #5
I own original intact membrane but I need it to outbid
Old 7th November 2012, 06:56 PM   #6
If you know how to remove the original glue
And do the rest of the job ( voice coil former , the wires , centering , glue it
to the spider ,then the external suspension )
Here , a professional worker takes 40$ per hour
Old 7th November 2012, 07:01 PM   #7
how to remove glue? acetone?
Old 7th November 2012, 07:04 PM   #8
Mooly's Avatar
Repair speaker
They look a bit like the Kevlar midrange drivers in my B&W's. There's very little cone movement on a mid so you might get away with patching the rip. Its not my field of expertise but I would perhaps be looking at some fabric "pasted" over it using something tough but slightly flexible to glue it. Polyurethane varnish maybe ?
Old 7th November 2012, 07:08 PM   #9
So are the speakers bowers
Old 7th November 2012, 07:19 PM   #10
Mooly's Avatar
Repair speaker
The yellow woven cone looks very similar.
Bowers & Wilkins - Kevlar
http://www.hifiportal.co.uk/Articles...r%20design.pdf
Repair speakerHide this!Advertise here!
Speaker Repair GearHunter Multi-Way 4 10th May 2011 09:54 PM
Speaker Repair skaleth Multi-Way 6 14th December 2009 12:41 PM
Speaker repair.. stevef51 Multi-Way 5 28th October 2008 09:23 PM
Speaker repair patknk939 Multi-Way 17 16th February 2008 10:44 AM
Speaker Repair bhg41088 Multi-Way 0 17th December 2004 01:57 AM
