Revision to JBL C.N. 270637 for BSC
Old 7th November 2012, 08:49 AM   #1
Kwikas is offline Kwikas  Australia
Default Revision to JBL C.N. 270637 for BSC
Some help here please.
I'm building them from scratch - different shaped box (same volume). BUT, they will be used for surrounds and installed 'in-wall' with the speaker baffle exactly flush with the wall.
What components on the crossover network should I try swapping/experimenting with to get rid of or reduce the BSC.?
I can do measurements in the final analysis but need some idea around the component(s) I should look at before I construct the crossover. This will help me make allowances for swapping in/out before the final board make up is settled on and soldered.
Appreciate your help....
Old 7th November 2012, 06:09 PM   #2
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Most likely if this design has BSC it has been done with an oversize bass in inductor in combination with a capacitor that doesnt turn over till the crossover region.
Revision to JBL C.N. 270637 for BSCHide this!Advertise here!
May AYA II, Revision A DAC Algar_emi Digital Source 6 10th August 2012 07:26 PM
EAS Controller revision A pra3718 Chip Amps 9 8th March 2011 09:31 AM
Northcreek Okara Revision Question mevaniuck Multi-Way 3 2nd July 2006 07:15 AM
