Why the lack of 10" coaxes?
Old 25th November 2012, 12:51 AM   #51
googlyone is offline googlyone  Australia
Winslow - I promised to keep you posted on some measurements of the BEYMA 10XC25.
Tests I did today have shown that:
- The 1/3 octave smoothed measurements are very (very) close to those published by Beyma.
- A close investigation of the published plots indicated there may be a bit of fun ang games to get a relatively smooth an uncoloured response.
- Making measurements without smoothing there are a couple of features that really impact these for use outside sound reinforcement - in my humble opinion...
Beyma 10xc25 Nopara.pdf
Things of relevance to these measurements:
- Driver mounted in 280mm wide, 320mm high closed box stuffed with wool. (sizes approximate)
- Enclosure about 1.3 metres from floor and ceiling.
- Measurement made at 1 metre on axis
- Behringer cal mic used
- SPL something in the order of 90-100dB
- Gated measurements used - hence loss of meaningful data at low frequencies. (Cut off plots)
The top 3 plots have no smoothing applied at all. When smoothed these are remarkably similar to the Beyma data.
I also measured the second driver, which coincidentally I just reconed, and the response is smack on the OEM response. A nice thing to see!
The way I think Beyma address the rising response in the bass unit is to put the XO at 2KHz (if I recall 2.2?) and use this to roll off the rising response of the bass unit.
That dip in the horn is there, and is real. Without active EQ not a lot is going to fix that. That said, the unsmoothed response is rather unflattering - when run through a 1/3 octave smoothing, there is still a dip but it does not look like a chasm.
The plot showing bass and horn response is rather daunting... A quick listen to the bass driver shows it really does need some work.
I have not had a lot of time to think this through yet - but did choose to play with some active EQ on this to see how it could be "beaten into submission". I have not tried to be elegant e.g. using the rolloff of a high order XO's on the bass unit to flatten out the peak - just for now I "smacked it down" with a parametric EQ.
That said, with enough EQ you get the response shown at the bottom. It looks better than is sounds - though I suspect that a pair of these with a sub would be respectable.
Just for giggles - here is what I did in terms of EQ...
- BASS Unit EQ1:
Type: Parametric
Centre Freq: 1700Hz
Q: 4
Gain: +5dB
- BASS Unit EQ2:
Type: Parametric
Centre Freq: 300Hz
Q: 0.8
Gain:-5dB
- BASS Unit EQ3:
Type: Parametric
Centre Freq: 500Hz
Q: 10
Gain: +10dB
- Horn Unit EQ1:
Type: Parametric
Centre Freq: 7000Hz
Q: 0.7
Gain: +10dB
- Horn Unit EQ2:
Type: Parametric
Centre Freq: 4850Hz
Q: 10
Gain: +10dB
- Horn Unit EQ3:
Type: Parametric
Centre Freq: 7000Hz (yes - but High Q)
Q: 10
Gain: +10dB
Would I use them like this? No.
Will they work, and would they be good for PA? Yes
Are they HIFI? I don't think so yet...
Old 9th December 2012, 12:23 AM   #52
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by JRKO View Post
10" coax for the car?!?!
Aren't the benefit of a 'point source' driver kinda nullified with legs, tunnel & shifter in the way and unequal listening distances/angles?
At home I used Gedlee Summas, but nearly all of my car audio experiments have been variations on a point-source speaker, or approximating one. And the reason is very simple:
You're sitting very close to the drivers.
For instance, if I listen to my Summas at a distance of 4-6 meters, they blend well. But if you listen to them very close, the transition to the midrange suffers because you're in the nearfield.
Long story short, I prefer not to listen to speakers in the nearfield, and in the car that's hard to do because of the large distances between woofer and tweeter.
Why the lack of 10" coaxes?Hide this!Advertise here!
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
kinda ot... 10" x 10" x 10" aluminum block/bar, does such thing exist? Mickey Pass Labs 9 15th November 2011 08:22 PM
Vintage Audax A150-X 15" coaxes whiteSE Swap Meet 2 1st January 2007 08:02 PM
BMS's new 12" coaxes Pallas Multi-Way 0 26th April 2005 06:07 AM
Copyright ©1999-2017 diyAudio
