#41 | |
I am guessing they are weights (perhaps vectors and not constants) that are a function of something ? |
#42 |
Those are just scalar weight constants.
Phi is sort of a "projection blend control" angle and is used from 15° to 75°. 90° gives no center signal and pure L/R, while 0° gives an M/S-decoding. W is the stereo width parameter and is nominally 1, allowing for fine tuning. See UsPat#5594800, fig4 and description. |
#43 |
@Markus : Tannoy 15"
#44 | |
In Trifield the audio band is divided in two parts and both parts have a matrix but the coefficients are a bit different for each band. The transition freq is somewhere in few kHz. I think there is no benefit to use a matrix at bass freqs (since bass is mixed mostly mono anyway), so it would be feasible to matrix satellite speakers and keep bass separate. Or as you say put bass only in side speakers and play them ordinary stereo at low freqs. At the moment in my experimental system the bass is not matrixed below about 100 Hz. I don't see any problems with that. - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#45 | |
On the other hand, by using linear phase filters do you think you could arrive in same perception as with original Trifield matrix ? I believe Gerzon did not just put some numbers in his articles and patent but they were based on extensive listening tests. I also assume his filters were not linear phase. So if you change the filters you'll get something else perhaps but not Trifield ? - Elias
#46 | ||
So basically the split is done to "strech" the higher frequencies further apart (less power goes to center, more goes to L and R) I wonder if one cannot get a similar effect "built-in" the loudspeakers themselves by boosting the highs on the L+R and rolling them off for the center ? The whole should still sum flat and it's not exactly tri-field, but it could still work. Quote:
So I'll give it a try sometime.
I don't believe in audio believings. |
#47 | |
For low freq (phi = 35 deg) you get: C3 ~ 0.58(L+R) L3 ~ 0.78L - 0.21R (similar for R3) For highs ((phi = 55 deg)) you get: C3 ~ 0.40(L+R) L3 ~ 0.90L - 0.09R (similar for R3) So you can't achieve exactly the same effect by rolling off the high freq on the center, because the phi also controls the "mix" in the L and R, but one might get away with rolling off the center ~3dB down above 5kHz and still getting a good effect, while avoiding additional high/low pass filtering in the matrix circuit.
#48 | |
This conclusion was the basis for movie theaters installing 5 speakers behind the screen - though it was shrunk to three in the early eighties. |
#49 | |
#50 | ||
A metal plate hit by a wooden stick In some music there is two metal plates hitting each others in a consecutive on-off manner
| Planar & Ribbon Speaker Equations | rockguitardude | Planars & Exotics | 11 | 1st June 2011 05:40 AM |
| Me again... matrix decoding w/ tubes? | sixSixSeven | Tubes / Valves | 1 | 23rd March 2011 03:33 PM |
| Stereo to 5.1 hafler matrix decoder | Nordic | Chip Amps | 14 | 18th January 2006 11:15 AM |
| decoding input | guinness | Car Audio | 1 | 16th November 2004 11:22 PM |
| Trinaural - Anyone heard this? | Bill Fitzpatrick | Multi-Way | 11 | 17th January 2003 09:17 PM |
