#31 | |
Personally I was thinking about linear phase filters because 1st order analog, while summing linphase, has 90° phase between bands, and acoustic centers of same bands are far apart (speaker-2-speaker distance) so the there could be some off-axis ill effects that might be avoidable with round kneed, gentle slope linphase filters with compact, non-ringing FIR kernels. I'm FIR based anyway and integrating the Trifield matrixing would not cause any computational resource penalties... still waiting for my new coax drivers (4pcs) but then I'll be eager to try TriField and find out if it significantly betters the simpler Trinaural. |
#32 |
Here's the trinaural matrix
![]() Fullfils matrix equations: Ls = L - 0.5*R Rs = R - 0.5*L Cs = 0.5*L + 0.5*R - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#33 | |
The comb filtering noticeably changes the timbral balance of the singer - but then again, just about all recordings have a final mastering on a 2-speaker playback system, and the EQ is intended for 2-speaker playback (with a secondary cross-check for single-driver lo-fi mono playback). Just guessing here, but I'd imagine that vocals sound a bit more direct and "up-front" on a symmetric 3-speaker playback system, due to the absence of comb filtering for the centered singers. |
#34 | |
I don't know yet is this due to less comb filtering of 3 speaker stereo, or because of increased 'ambiance' due to difference side signal +/- k*(L-R) which is present at both side speakers. - Elias
#35 | |||
Yes, but only in internet forums I have found people that would object. All "real" people I've ever met never had the phantom imaging problems you describe.
Markus |
#36 | |
I think it has to do with comb filtering between the two speakers to which I might be "over sensitive" (takes me out of the illusion), so this trinaural approach looks tempting... |
#37 | ||||
Elias used unequalized pink noise, so I understand his results. If I am not mistaken(and I could be), Bell Labs came to the same conclusion as Elias has |
#38 | |
Looking at some of the articles quoted in the thread, I am not sure I understand: where do 1st order low/high filters come into play? I thought matrixing was done at all frequencies, or is Trifield different ? Are there actually 3-speakers solutions that do NOT assume that the center speaker is identical to L and R ? The approach sounds promising and I would like to test it, but not if it means another bulky loudspeaker in the middle. How about if the center would only reproduce >100Hz, would the concept still work and would it change the matrixing ? Interesting thread, btw.
I don't believe in audio believings. |
#39 | |
Markus |
#40 |
Please keep us posted. What coax are you getting?
Markus |
| Planar & Ribbon Speaker Equations | rockguitardude | Planars & Exotics | 11 | 1st June 2011 05:40 AM |
| Me again... matrix decoding w/ tubes? | sixSixSeven | Tubes / Valves | 1 | 23rd March 2011 03:33 PM |
| Stereo to 5.1 hafler matrix decoder | Nordic | Chip Amps | 14 | 18th January 2006 11:15 AM |
| decoding input | guinness | Car Audio | 1 | 16th November 2004 11:22 PM |
| Trinaural - Anyone heard this? | Bill Fitzpatrick | Multi-Way | 11 | 17th January 2003 09:17 PM |
