#21 | |
I've done comb filtering perception listening tests using mono pink noise (worst possible signal) and 3 speakers are much better than 2. Here's some of my subjective results I did just recently: Elias Pekonen Home Page - 2 vs 3 Speaker Stereo listening tests at high frequencies - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#22 |
very interesting, thank you
#23 | |
These are the only two times I was impressed with PLII |
#24 |
Griesinger has some interesting PPT slides up on his webpage about "Pitch, Timbre, and Source Separation".
Markus |
#25 | |
![]() I strongly disagree with your statement "center phantom image weak or non existent" for 2-speaker stereo with high pass filtered music. I do get a stable phantom center from high pass filtered (48dB@1.6kHz) stereo music tracks. Possible explanations for your findings: - Low direct/reverberation ratio. Is your room treated in any way? What kind of speaker directivity was used? - Difference in localization perception. There are reports that some people can't localize phantom images. You've reported similar perceptions in the past. You should have other people listen to your test in your room and report their observations.
Markus |
#26 | |
Nobody said more speakers are bad (think Ambisonics
) but certainly it is more efficient to use only one stereo speaker ![]() It looks like 2 speakers is the worst scenario. Quote:
There is published scientific evidence that humans cannot perceive phantom images at very high freqs (the reference was given in another diyaudio thread). That is the problem of 2 speaker stereo. 3 speaker matrix stereo seems to solve this problem somehow. - Elias
#27 | |
...in your personal priority list of what sound reproduction needs to be capable of. That list might not be the same for everybody. My priorities are certainly different.
You skipped over my questions about room and speaker characteristics in your listening test.
Markus Last edited by markus76; 6th November 2012 at 11:46 AM. |
#28 | |
When there is less signal energy at 1 kHz and more energy above 6kHz there is no phantom imaging and only the two speakers will be perceived. So, overall the 2 speaker stereo does not work very well in terms of phantom imaging. That is highly subjective statement
#29 | |
![]() I prefer music were - by and large - the harmonics roll off with rising frequency. Rudolf
www.dipolplus.de |
#30 |
Heres my experimental matrix system at proto stage. Three FRS8 at reinforced cardboard dipole baffles
Matrixed for coefficient of 0.5. Very old proto speaker has been forced laying on the floor to serve as a dipole bass below about 100Hz.Sound... amazing ![]() - Elias
| Planar & Ribbon Speaker Equations | rockguitardude | Planars & Exotics | 11 | 1st June 2011 05:40 AM |
| Me again... matrix decoding w/ tubes? | sixSixSeven | Tubes / Valves | 1 | 23rd March 2011 03:33 PM |
| Stereo to 5.1 hafler matrix decoder | Nordic | Chip Amps | 14 | 18th January 2006 11:15 AM |
| decoding input | guinness | Car Audio | 1 | 16th November 2004 11:22 PM |
| Trinaural - Anyone heard this? | Bill Fitzpatrick | Multi-Way | 11 | 17th January 2003 09:17 PM |
