Trinaural decoding equations for 3 speaker stereo matrix ?
Old 26th July 2013, 05:40 AM   #171
Lynn Olson is offline Lynn Olson  United States
Lynn Olson's Avatar
I'm curious, ro9397, about your listening experience with a well-tuned 3-channel system (using 2-channel sources). The Ariels project a phantom center that is quite noticeably elevated, by about 3 feet, or well above the height of the 48" high Ariels. When I engage the semi-mid-fi Marantz receiver and use the Center speaker, the image elevation ceases, and is pinned on a midline between the three speakers. Do this happen with Trinaural, or does the Center image remain as elevated as it does in 2-speaker playback?
Also curious about depth distortion. I found that depth perception seems to be critically dependent on Center level, with too-high Center levels reducing the impression of depth behind the speaker array. It hardly matters for movie soundtracks, since they have pretty poor spatial mixing anyway, but it makes a big difference for 2-channel music sources, where depth cues are an important part of the mix.
I have heard superb mixes from discrete 3-channel sources and matched speakers and amplifiers, but only have limited experience with static 3-channel decoders. Back in the day, I did plenty of listening to dynamic decoders like the Shadow Vector, CBS Paramatrix, Tate DES, and Sansui QS, and have learned the artifacts of dynamic decoders (odd shifting impressions, listening fatigue, unwanted detenting at loudspeaker locations, etc.)
The usual downside with most static matrix decoders is blurred localization, although this can skillfully arranged with crosstalk terms ... for example, a moderate degree of antiphase crosstalk in the L and R speakers, which offsets the image narrowing of a too-simple L = 1.0, C = L 0.5, R 0.5, and R = 1.0 decoder.
My limited experience with 3-speaker playback is much greater clarity and transparency for central and near-central sounds, which is very welcome with nearly any recording, but level setting and subjective timbre-matching can be a little tricky. How's it been for you?
Old 26th July 2013, 01:56 PM   #172
Paul W is offline Paul W  United States
Paul W's Avatar
In the mid 80's I tried 3 identical speakers wired as Elias shows them and found imaging too vague (for me). Seemed everything was stretched across the stage. Admittedly, I am an imaging junkie so those who aren't may really like it. (I also remember a slightly distorted center, but chalked that up to stylus mistracking.)
Paul
Old 26th July 2013, 04:13 PM   #173
ro9397 is offline ro9397  United States
Within 48 hours I'll experiment and take notes. Till then I'll go by memory. Last stereo audition was a couple days ago.
Trinaural inserts between source and multi channel preamp. For stereo, Trinaural is turned off, CDP directly drives the preamp, and a thick winter comforter completely covers the C Ch speaker.
LCR mains are matched improved clones of the stellar $5k/pr French ASA Pro Monitors designed by a recording engineer: Dynaudio Esotec, every detail highly refined, electrical 1st order in-phase, PIO series tweeter caps trimmed to 2nd decimal or better, litz series mid bass coil, Zobel network, time-aligned with mid bass at ear level/above tweeter with slight tilt back, 1.25" panels (old growth Baltic Birch ply over wood by product), 38# each. Stands are 40# refined/overbuilt DIY "Stubby" with sand filled 5" square vertical support.
CDP is Paul Weitzel/TRL modified Sony DVP-NS900V (DVD deleted, SACD stereo output only). In direct A-B over several weeks, with unbalanced CDP the multi-ch line preamp was indistinguishable from my $7500 Bongiorno designed SST Ambrosia. Amps are pure analog chips, 100W but rated only for 8 Ohm load (think of them like a SS OTL) with long list of passive mods...on the right load the only thing I miss about my Hypex Ncore NC400 mono blocs is wider/deeper stage.
Rooom is well treated, OC703 with ultra high tech dispersion film (newspaper, cryo treated...sarcasm last two words). Normal function (Trinaural) is four piece Distributed Sub Array employing Trinaural internal active high pass for main speakers, in-phase 2nd order @ 80 Hz. Stereo/Trinaural A-B requires subs turned off and mains run full range (toggle switch on Trinaural). Mains cutoff mid to high 40 Hz anechoic, lower in room.
Whew...to your point: yes, definitely in stereo center image is elevated, possibly even as high as with your lovely classic Ariel, which I have long wanted to audition.
Open to review, but first thought is Trinaural definitely does indeed lower the image, again, about same as you describe.
Which Processing function to you employ to derive the C Ch? (I once compared Trinaural to the DSP in my Pioneer receiver, the latter which sounded unbelievably awful.)
Again, ditto. My experience is that C Ch level is critical and requires adjustment. You earlier suggested one might benefit by adjusting C Ch level per track. For some CD's such as live solo piano one setting is fine while other CDs benefit by adjusting per track. Still, cost to benefit ratio favors Trinaural over stereo.
Agreed, with clarification. Comparing my CDP > Trinaural vs. Pioneer HT DAC/DSP grossly favors the former. OTOH, large world class orchestra recorded at Abbey Road and/or Air Lyndhurst studios in London, such as The Hobbit score, played through the Pioneer, is among the best reproduced sound I've heard. Black Hawk Down is another absolutely stellar sound track. I can not overstate how incredibly huge is the stage of such sound tracks, epic scale and layering of depth and breadth, like your eyes are attached to the mic boom overseeing a sea of orchestra members.
Dual use music/HT employs perforated retractable 92" screen, dead quiet Mitsubishi 1080P projector, and total light control (basement with only one light well).
I have plenty of experience with systems that make one daydream and want to do something else.
This system invites one to listen for several hours at a stretch. The only thing that makes me want to do something else is running out of good music. (My vinyl collection is much better than my CD collection.)
Yes, my experience is similar. As I mentioned earlier, I find the C Ch level control virtually indispensable. Without it I don't really think it works.
For instance, take a solo ultra high end classical guitar like the one played by John Williams on a CD. I sell such guitars and play guitar, so I know the correct image "size" and proper blend of center image with the "reverb" apparently mixed in by the engineer. Proper C Ch level gets this blend just perfect where one hears what appears to be a live guitarist playing on a bench or chair and proper mixture of late arriving boundary effects in the original room, which in reality is an artificial construct of the engineer. It the C Ch level is wrong, there's either too much LR speaker reverberant effect with the direct guitar sound blurred, or the opposite which is too much direct guitar sound in the C Ch and too little reverberant sound from the LR.
With orchestra such as spaced omni Telarc, when it's right you just can not believe the arc of the orchestra in every plane. Likely the best stereo playback I ever heard was the late Bob Crump's last CES display prior to his untimely demise (RIP). That system may be the only one to equal or approach a properly tuned Trinaural system (unfortunately I only played one recording being a well engineered solo live jazz/boogie piano). When Trinaural C Ch level is wrong the depth is flat.
I love to play Telarc's Tchaikovsky 4th Symphony for visitors. This system allows listeners to hear every counterpoint line and still enjoy the whole, keeping them keenly interested in the composers intent as he carries them on an epic and brilliant musical journey. The atmosphere around each orchestra group is incredible, as is the layering in all planes. On lesser systems this is impossible and this is one of the reasons people can't enjoy more complex pieces.
James
"Television is the poor man's whiskey." Russel Baker
Old 26th July 2013, 06:21 PM   #174
Elias is offline Elias  Finland
Elias's Avatar
I should mention in passing the comb-filter coloration that appears in 2-speaker playback with centered sources can be alleviated with quite low Center levels, possibly as low as:
Center = Left 0.223 + Right 0.223, which is 10 dB lower than the usual pan-pot level of Center = Left 0.707 + Right 0.707 (assuming Left = 1.0 and Right = 1.0)
If the primary aim of the Center speaker is to reduce coloration on vocals, as opposed to greater image stability, the optimum Center level may indeed be lower than the usual recommendations.
Maybe, what you state, it is a sort of lower level limit of center speaker signal, and one should not go under it. While even small level at center speaker reduces comb filtering, I think the full benefit of center speaker comes from enhancing center image especially for non center listeners.
What I am not sure of is the effect of Center level on image depth; this is where three symmetrical loudspeakers with identical diffraction signatures and crossovers may be necessary for image stability and reduced listening fatigue. (The one sure sign of incorrect multichannel setup is more listening fatigue than straight 2-speaker stereo.)
If the depth begins to suffer, that may be a sign that the Center level is too high for that particular recording ... annoyingly, with modern recordings sourced from studios all around the world, it might be necessary to adjust Center levels on a track-by-track basis.
I think there are more to image depth than center speaker level only. More inportant is what is the decoder 'side signal'.
In terms of MS-stereo (Mid, Side), some part of side signal S should be sent to side speakers. In MS stereo M and S are
M = 1/sqrt(2)*(L + R)
S = 1/sqrt(2)*(L - R)
In this case the matrixed output can be written in MS format as
Ls = 1/sqrt(2)*(0.5 M + 1.5 S)
Cs = sqrt(2)*0.5 M
Rs = 1/sqrt(2)*(0.5 M - 1.5 S)
we can simplify
M = L + R
S = L - R
and
Ls = 0.5 M + 1.5 S
Cs = M
Rs = 0.5 M - 1.5 S
So in this matrix the 'side signal' at the side speaker is 3 times bigger than 'mid signal'
In recordings the 'side signal' contains clues of the recording space. It is beneficial to present the signal S through side speakers.
In practice, both user adjustable Center level and moderate degree of Center-channel EQ may desirable (preferably on a remote). For example, a slight degree of HF rolloff starting at 5~8 kHz might be necessary to subjectively timbre-match the Left and Right speakers; even though all speakers might measure identically, remember that your ears have a different spectral response for sounds arriving directly in front versus phantom images created from speakers that are 20 to 30 degrees off-center. What you need is a subjective tonal match, preferably made with a pink-noise source, for all L, C, and R image locations, and all intermediate locations in between.
I'm not sure if there should be EQ or not. Because it is natural perception to have tonal balance varying with the incidence angle. We can think that tonal balance is correctly perceived when dominating energy comes from the intended direction.
Only that 2 speaker stereo cannot do center image properly because all the sound comes from two side locations only.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 26th July 2013, 06:38 PM   #175
Elias's Avatar
Don't you think it would already be time to try again ? Everyone should try 3 speaker stereo at least once in a century.
Maybe it's the conventional confrontation: Unrealistically small sized pin-point image vs. realistically sized image with real ASW.
Old 27th July 2013, 02:00 PM   #176
Paul W's Avatar
Current system is 11.1 with a center but, you're right, I should try that setup again.
Paul
Old 11th September 2013, 09:24 AM   #177
graaf is offline graaf  Poland
graaf's Avatar
I've been enjoying 3 flooders played through the matrix, and even the crappiest recordings got immediatelly improved and became almost pleasurable.
Can You please give some more details about Your current setup?
"high phooey and hystereo" - Yascha Heifetz
Old 11th September 2013, 04:53 PM   #178
Apology if I mentioned this earlier. IMO a remote "trim"/level control for the C Channel is critical. Jim Smith (former importer Avant Garde horns) advised that Trinaural performance suffers with spaced omni recordings ala Telarc and others.
He's correct, but only if users follow Trinaural inventor Bongiorno's advice to set and forget C Channel level.
I set the Trinaural C Channel level pot (slotted screw driver) for LCR unity gain with a tone generator input/volt meter @ output. (Interestingly, unity gain requires the C Channel pot about +15 degrees above maximum counterclockwise rotation. IMO the lack of preset unity gain is a Trinaural failure, though one can work around it as I did. Another failure is no stereo/Trinaural switch to instantly compare.)
Signal path:
Stereo analog source (TRL/Paul Weitzel modified Sony DVP-NS900V SACD stereo only, Custom Empire 509 TT/Strainguage demodulator) >
Hard wired gold contact toggle switch box >
Trinaural Processor 3.1 analog output, 80 Hz split >
Custom multi-channel line preamp (indistinguishable from my $7500 Bongiorno SSI Ambrosia/2012 TAS Component of the Year) >
Three matched LCR amps (also 950W sub amp powers four distributed subs/proprietary setup, +/-3 dB 100 to 20 Hz throughout the room sans EQ, -1.5 dB @ 20 Hz, conservative 113 dB clean output) >
Three matched LCR custom Dynaudio Esotec monitors (six improved clones of stellar French ASA Pro Monitors, two boxes per channel, patent-pending Late Ceiling Splash radiation pattern)
When the preamp LCD reads "C Ch 0.0 dB" front LCR levels are matched. The large room is symmetrical.
Spaced omni recordings requires C Ch -4 to -6 dB. Lest one think this C Ch level so weak that stereo would be preferred, Trinaural still is preferred.
Other than spaced omni recordings: I estimate 1/3rd sound ideal with C Ch level flat, 1/3rd -1 to -3 dB, 1/3rd +1 to +3 dB.
I never heard it, but NuForce recently released an attractive 8-ch line preamp, balanced/unbalanced inputs/outputs, only $1k MSRP.
James
Old 9th October 2013, 08:13 AM   #179
markus76 is offline markus76  Germany
Banned
Here's a new BBC paper discussing ambisonics vs. multichannel:
http://downloads.bbc.co.uk/rd/pubs/w...les/WHP254.pdf
Old 9th October 2013, 04:00 PM   #180
Elias's Avatar
Kind of interesting that BBC is still supporting Ambisonics, after all these decades it has been like pushed with a rope
Ambisonics will never die, long live Ambisonics !
Trinaural decoding equations for 3 speaker stereo matrix ?Hide this!Advertise here!
Planar & Ribbon Speaker Equations rockguitardude Planars & Exotics 11 1st June 2011 05:40 AM
Me again... matrix decoding w/ tubes? sixSixSeven Tubes / Valves 1 23rd March 2011 03:33 PM
Stereo to 5.1 hafler matrix decoder Nordic Chip Amps 14 18th January 2006 11:15 AM
decoding input guinness Car Audio 1 16th November 2004 11:22 PM
Trinaural - Anyone heard this? Bill Fitzpatrick Multi-Way 11 17th January 2003 09:17 PM
