#131 |
Last week I was listening to a 2-> 3 matrix with coeff 0.5 in Reaper (I'll upgrade to Markus' script, thanks for posting that). For the afternoon I'm using Dolby PLIIx from my soundcard (Xonar) output.
What exactly does it do frequency wise? It cuts up processing band by band, but how? The Wikipedia article doesn't really say. Or am I totally mistaken and it is just a sqrt(2) center if I'm using 3 speakers. |
#132 | |
I lifted the tubes so that elements are on ear height. First listened with elements aimed to the listener, then aimed the elements towards the ceiling. This was with passive matrix wiring with coefficient of 0.5. So they were kind of omnis.Then I placed a large (60*80cm) baffles just behind each tube to make them 2pi radiators, and it was much better ! Omni midrange ? I don't like it very much. It sounds too ambigouos and not very clear. Half space midrange is better, also with matrix. - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#134 |
#135 |
If you use the energy-preserving code then remove the 3dB attenuation for the center. Simply replace
Code:
c_out = 0.7071*m_c; Code:
c_out = m_c;
Markus |
#136 |
#137 |
Just for the sake of completeness here's the "final" Reaper code for a energy-preserving matrix decoder after Gerzon:
http://mehlau.net/audio/matrix_decoder/
Markus |
#138 | |
I found some more confirmation on Trinaural matrix coefficients from here
http://www.nubert-forum.de/nuforum/v...42a5023fc0a493 And the matrix coefficients according to them are: Quote:
The thing I don't know is how they know it ![]() - Elias
#139 |
That's TriSonic (AES Preprint: "An Optimum Linear-Matrix Stereo Imaging System") with a matrix factor of 0.5.
Just a sub-version of Gerzon's energy-preserving decoder.
Markus |
#140 |
A post by Elias just got lost?
Markus |
| Planar & Ribbon Speaker Equations | rockguitardude | Planars & Exotics | 11 | 1st June 2011 05:40 AM |
| Me again... matrix decoding w/ tubes? | sixSixSeven | Tubes / Valves | 1 | 23rd March 2011 03:33 PM |
| Stereo to 5.1 hafler matrix decoder | Nordic | Chip Amps | 14 | 18th January 2006 11:15 AM |
| decoding input | guinness | Car Audio | 1 | 16th November 2004 11:22 PM |
| Trinaural - Anyone heard this? | Bill Fitzpatrick | Multi-Way | 11 | 17th January 2003 09:17 PM |
