Trinaural decoding equations for 3 speaker stereo matrix ?
Old 6th January 2013, 12:07 PM   #121
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by markus76 View Post
Interesting observation: the center doesn't seem to be particularly stable with head movements.
If your system is like in your pic in post #75, you may note the center speaker is having about 6dB less direct sound in the midrange than the side speakers since the baffle step occurs in considerable higher in frequency. In addition your heavily absorbed front wall makes the center speaker a 4pi radiator while side speakers are radiating in 2pi. This gain mismatch is the propable reason to unstable center phantoms you experience.
Have you tried with speakers being all identical ?
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 6th January 2013, 12:14 PM   #122
Elias's Avatar
Gerzon states in his 1991 AES convention paper #3180 that "loudspeakers [that] lie along a straight line [...] generally give[s] less good results".
I think, and it looks like that in theory, if the listening is performed in a strict miniature spot without lateral movements, the speaker arch with identical distances to the listening position may be better. However for any off-center listener the speaker line looks like a much better alternative. And here I'm not thinking about tiny head movements of few cm but large shifts like up to 1m.
Personally I dont like tiny listening spots. Currently I have my 3 speakers in a line and it works well in almost everywhere in my room.
- Elias
Old 6th January 2013, 05:09 PM   #123
Elias's Avatar
Originally Posted by KSTR View Post
Bongiorno's Trinaural is the same as Miles' Optimum Linear Matrix with k=0.5 and also one of Gerzon's TriField variants, if I gather up things correctly.
I used the search function and found this post from KSTR:
Horn vs. Waveguide
post #884
If anyone is interested, I have some detailed insight of James Bongiorno's "Trinaural" (a subset of the "Optimum Linear Matrix", as described by Michael Miles). Could even give you the detailed schematic (but I won't, of course. I respect IP).
Basically it's an an ultra-simply analog matrix, completely LTI (if you have balanced connections, 13 resistors will do it damn close to the real thing). And it works like charms... I swear. It creates an artifical but very supportive (for the illusion that stereo is all about, anyway) sensation of a different vertical size/expansion/pattern, giving way more seperation between instruments and between direct and reverberant sounds (as encoded in the recording). It not easy to describe that in words (for me as a non-native speaker, at least).
And the sweet spot is huge (laterally). Toe-In of speakers (that is, "trading" as the effect in stereo psychoacoustics is called, compensating dT with dL) doesn't work for me at all to widen the sweet spot. It still is pretty balanced stereo in the lower registers, but all sensation of space is lost. Sondstage collapses to a straight 1D line between the speakers.
But not in this thread. Better we go here :
Linear 2-->3 Rematrixing for Speaker Signals
- Klaus
If this is indeed correct, then Trinaural equations are based on coefficient of 0.5. And my question in original post has been answered Thank you.
- Elias
Old 6th January 2013, 08:03 PM   #124
Soundtrackmixer is offline Soundtrackmixer  United States
That is because of a time arrival issue. If you are sitting along the center line between the L/R speakers, the center speaker is actually closer to you than the L/R are. This will perceptively reduce the stereo seperation of the L/R mains in favor of a strong mono center image.
Soundtrackmixer - M.P.S.E/AES/SMPTE member
Old 6th January 2013, 08:26 PM   #125
markus76 is offline markus76  Germany
Banned
Which is a forerunner of the "energy-preserving matrix decoder" which in turn is a forerunner of the "frequency-dependent energy-preserving matrix decoder" to which I'm listening right now
Trinaural decoding equations for 3 speaker stereo matrix ?-fdep2x3md-png
(From Gerzon's AES convention paper #3180)
Old 7th January 2013, 08:19 AM   #126
lolo is offline lolo  France
lolo's Avatar
What about directivity? I finally had 2 hours for myself last night and experimented with three quickly made pipe speakers, matrix from my old denon receiver and dayton RS100. It works! More so on hard panned effects than orchestras but it's a good start. Only two drivers at the opposite end of a horizontal pipe worked well too, sounds a bit like a corner setup in some ways.
Is omnidirectionality good in the mids? Wouldn't a narrower CD all the way down to 100-200hz be better? I know, not an easy thing to achieve.. but I feel there is considerable leak in that range going straight to the ear and not towards the wall..
Old 7th January 2013, 08:24 AM   #127
Banned
But is omnidirectionality good in the mids? Wouldn't CD all the way down to 100-200hz be better? I know, not an easy thing to achieve..
It's the old question for which we still don't have a good answer, "How much room is needed?", i.e. what reflection pattern is optimal.
Old 7th January 2013, 08:40 AM   #128
lolo's Avatar
Sure, but for this specific application it seems to me you ONLY want the room!
BTW, a corner setup sounds good too. It shows that stereo needs quite a large spread to works well, in my opinion..
Old 7th January 2013, 09:17 AM   #129
Elias's Avatar
So you have done something similar to Stereolith ?
Old 7th January 2013, 09:38 AM   #130
lolo's Avatar
maybe?
I am very keen to know what you have to say about the directivity issue.
Trinaural decoding equations for 3 speaker stereo matrix ?Hide this!Advertise here!
Planar & Ribbon Speaker Equations rockguitardude Planars & Exotics 11 1st June 2011 05:40 AM
Me again... matrix decoding w/ tubes? sixSixSeven Tubes / Valves 1 23rd March 2011 03:33 PM
Stereo to 5.1 hafler matrix decoder Nordic Chip Amps 14 18th January 2006 11:15 AM
decoding input guinness Car Audio 1 16th November 2004 11:22 PM
Trinaural - Anyone heard this? Bill Fitzpatrick Multi-Way 11 17th January 2003 09:17 PM
