Old 4th January 2013, 02:54 PM   #111
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by markus76 View Post
Interesting observation: the center doesn't seem to be particularly stable with head movements. The stability of phantom sources don't seem to benefit from an additional speaker.
What coefficients have you tried ? Sounds like totally opposite to my findings.
Home page
If our hearing would be accurate, we would be hearing two loudspeakers.
Old 4th January 2013, 03:37 PM   #112
Well, phantom center sources don't "snap" to the left or the right speaker when moving like they do with normal 2-speaker stereo. But the upmixed center speaker creates a considerable amount of ambiguity when moving.
Markus
Old 4th January 2013, 05:04 PM   #113
Elias's Avatar
You should try coefficient of 0.5. It maximises the separation between speakers. Did I suggest it already ?
If you are after the "snap" effect, that is the image locked into the speaker, then you will need much more directional speakers than FRS8.
On the other hand I find the "snap effect" one of the worst features (symptoms) of conventional 2 speaker stereo. It ruins the the rest of the little realism that would possibly have been there in ideal conditions
- Elias
Home page
Old 4th January 2013, 07:43 PM   #114
0.5 is the default in my script...
- Elias
I'm not after the "snap" effect. But in my current configuration it sounds more natural despite the spatial distortion. Pick your poison.
You know that Gerzon's techniques are based on assumptions that not everyone agrees with. See papers by Theile.
Markus
Old 4th January 2013, 08:12 PM   #115
Elias's Avatar
You might also try placing the 3 speakers in line instead of arch.
In my FDTD simulations it produces better wavefront for both center and off-center listeners:
Elias Pekonen Home Page - FDTD simulations of stereo speaker configurations in small room
- Elias
Home page
Old 4th January 2013, 08:22 PM   #116
Did you try placing L and R directly at the wall? The opening angle from the listening position should be about 45°. Adjust toe-in of speakers. This will influence the level of the contralateral reflections. How does that sound to you?
Markus
Old 5th January 2013, 09:49 AM   #117
Elias's Avatar
Yes I did try speakers at the side walls many years ago. All the sound was at the side and nothing much at the center. So it was not good at all. It was about the same time I understood there must be a speaker at the center to be able to generate stable center images. It also eventually lead me to my single speaker stereo SSS concept.
- Elias
Home page
Old 5th January 2013, 12:36 PM   #118
You have to get the toe-in right then "everything falls into place". Of course this is just a one seat solution but it works remarkably well.
Markus
Old 5th January 2013, 12:45 PM   #119
Gerzon states in his 1991 AES convention paper #3180 that "loudspeakers [that] lie along a straight line [...] generally give[s] less good results".
Markus
Old 5th January 2013, 01:08 PM   #120
Here's my implementation of a energy-preserving 3x2 matrix decoder:
Code:
desc: Energy-preserving 3x2 Matrix Decoder //based on Gerzon
slider1:35.26<-0,90,0.01>Angle parameter (0-90)
@slider
angle = slider1*0.017453;
@sample
l_in = spl0; r_in = spl1;
//create MS from Left/Right
m = 0.7071*(l_in+r_in);
s = 0.7071*(l_in-r_in);
//Energy Preservation
m_c = m*cos(angle);
m_lr = m*sin(angle);
//Re-matrix to Left/Right
l_out = 0.7071*(m_lr+s);
r_out = 0.7071*(m_lr-s);
c_out = 0.7071*m_c;
//output
spl0=l_out; // Left
spl1=r_out; // Right
spl2=c_out; // Center
I'm not sure if the mid signal for the center (after energy preservation) needs to be attenuated by 3dB or not. Anybody?
Schematic:
Markus
Planar & Ribbon Speaker Equations rockguitardude Planars & Exotics 11 1st June 2011 05:40 AM
Me again... matrix decoding w/ tubes? sixSixSeven Tubes / Valves 1 23rd March 2011 03:33 PM
Stereo to 5.1 hafler matrix decoder Nordic Chip Amps 14 18th January 2006 11:15 AM
decoding input guinness Car Audio 1 16th November 2004 11:22 PM
Trinaural - Anyone heard this? Bill Fitzpatrick Multi-Way 11 17th January 2003 09:17 PM
Copyright ©1999-2013 diyAudio
