Old 14th November 2012, 08:56 PM   #41
Speakerholic
Cal Weldon's Avatar
Originally Posted by mondogenerator View Post
stratus (strata?)
Stratum and Strati.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 14th November 2012, 09:36 PM   #42
mondogenerator's Avatar
lol. Man. I didnt think I was on that much of a ramble... insert "holey" where I said "window" and see if that helps.
Ill have to remember the stratum strati thing... lol. What are rock strata them:-)
It still amazes me every time I get something right
Old 14th November 2012, 09:49 PM   #43
chrisb is offline chrisb  Canada
ta? Lol I mean a holey brace. My point being that holey window like braces work effectively, and ply or MDF arent as different in comparison to when theyre being used as panels, in their strongest plane. [b] Laminated ply designs are wasteful and have been criticised for using the material in the same plane.
no doubt that the trans-lam approach (not necessarily restricted to sheet goods, as evidenced by some recent "butcher block" fabrications) allows for functional shapes and aesthetic design features not possible with flat sheet goods, but even with the most efficient nesting CNC routing software, the cut yield is atrocious, nay, criminal I say - and then there's the assembly and finishing labor
window braces - cute Cal - think horizontal roof trusses
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 14th November 2012, 10:18 PM   #44
Speakerholic
Cal Weldon's Avatar
Unless you make a fish wall that is.
window braces -
There's actually such a thing, not sure how I went that far off track though. It should have been obvious but...well you remember the 60's?
cute Cal -
Thank you. I thought you had stopped noticing.
What them Joyce thingees?
http://www.ebay.com/itm/1966-THUNDER...-/110753282993
Old 15th November 2012, 08:00 AM   #45
hysterical... 60s really took their toll I gather. Holey braces, in England where the language is almost spoken, are worn out elastic trouser suspenders. What you call a window brace is a pillar over here.
Old 15th November 2012, 03:23 PM   #46
Speakerholic
Cal Weldon's Avatar
Really? A pillar here is the same as a post or column. A window brace is either the brackets that support a shelf on the outside of your window for a flower pot or A/C unit or in the case of a car, it's like that part in the link above.
Old 15th November 2012, 03:50 PM   #47
JRKO's Avatar
Send a message via AIM to JRKO
how'd we get onto double glazing systems?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home
Old 15th November 2012, 04:04 PM   #48
to the best of my knowledge, since i dont drive, over here its a roof pillar, or A-pillar. Something of the like. Just like hood is bonnet. English is a weird language.
Old 15th November 2012, 04:10 PM   #49
Quite. A conveniant diversion from my earlier post, which was quite salient, for once.
I.e. That holey braces in MDF or ply arent worth comparing. Elsewhere in box construction, the strength of ply is valuable.
Old 15th November 2012, 04:21 PM   #50
badman is offline badman  United States
badman's Avatar
Anyone wanna guess what I'm building?
I'm doing a CNC setup with shelf bracing and yes, cut yield is atrocious (the circles were cutoffs from something else, so no waste there).
To get the most of the material I'm planning to make diffusors from the shelf brace cutouts, by simply stacking them and gluing them in hills and valleys. Not a Skyline but should be quite effective. The cutouts for the non-braced sections will be saved and re-cut into another translam enclosure shape, so I should wind up with somewhere around 50% overall material efficiency from the starting point of circles.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Bracing Howard Subwoofers 3 28th March 2012 01:55 PM
Transformer potting material? what material? rvrazvan Tubes / Valves 38 10th October 2011 05:02 PM
How much bracing is necessary? Frosteh Subwoofers 91 27th September 2011 11:59 PM
Enough bracing? Vikash Multi-Way 51 8th May 2006 05:58 PM
how much bracing is enough gwgjr31 Subwoofers 1 5th May 2006 06:57 AM
Copyright ©1999-2013 diyAudio
