Bracing material? - Page 11 - diyAudio
Old 17th November 2012, 10:59 AM   #101
JRKO's Avatar
Send a message via AIM to JRKO
Originally Posted by Baseballbat View Post
What is sufficient energy?
You should be telling us. You are telling us in no uncertain terms it can & will happen. How can we hope to cure the problem you say always exists unless you know how to start the problem off?
Heres how: You need sufficient volume, a badly designed & built cabinet and maybe a disc of test tones.
All of which are easily remidied by 1) not playing at 100db (85db to keep your hearing ), 2) don't be a wally when designing & building your cabinet and 3) listen to music not test tones
In other words: Its not an issue in a large percentage of cases in the real world. (There are always exceptions to the rule)
If I'm not making noise, I'm making something to make noise
Old 17th November 2012, 12:42 PM   #102
Originally Posted by JRKO View Post
Do you have practical experience in this field?
Maybe you should take a quick look at this post: Is enclousure strengthening needed?
You ignore the fact that normal people listen to music not test tones/sweeps
What are the differences between test tones and music?
What about that is wrong?
Everything?
Old 17th November 2012, 02:41 PM   #103
Wrong. No matter how much energy you put into it, the resonance is always there. And, at resonance, the panel is more likely to receive the energy, because both impedances, mass and stiffness, cancel out and there's only the resistance (the damping) working.
The impedances cancel out?
Consider a lead ball hanging on a string. It will have inertia due to its mass, and to move the ball we need enough force to overcome the inertia. Now, replace the string with a steel wire, fixed rather than hinged at both ends. The wire will act as a spring, and the spring will add to the inertia of the ball, thus even more force will be required. Increase the stiffness of the wire, and the force requirement will increase further. At no point does the stiffness 'cancel out' the inertia of the mass.
Old 17th November 2012, 02:56 PM   #104
What is the complex impedance of ANY resonant circuit (regardless if electrical, mechanical or acoustical) at resonance? The phase is zero, so the complex impedance is purely resistive. The impedances of mass and stiffness (or inductance and capacitance) cancel out, and only the damping resistive part works.
Come on, that are basics!
Old 17th November 2012, 03:09 PM   #105
mondogenerator's Avatar
A resonant system as i understand it, is at its simplest a 2nd order transfer function M-C-K system of mass M, damper C ,and compliance K. Much akin to a car suspension system. I must say that i thought the phase was 180deg not 0, but ive been wrong many times.
You are correct, just like in a parallel LC at resonance Xc and Xl cancel leaving R, resistive loss.
The real question is what level of loss is optimal, how to achieve it in a given panel in order to coincide with the resonance, and damp it optimally.
At all other frequencies, our attentions can then be turned to reflective and diffractive absorption.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 17th November 2012, 03:34 PM   #106
JRKO's Avatar
I see math not music. Can you hear it? Or can you only measure it?
I've said it before, I'll say it again. Music has been around since someone could repeatedly grunt at the same pitch. It exists now away from hifi and will continue to survive without hifi. The same cannot be said of hifi.
um let me see, Mozart, Sandy Denny, Joe Bonamassa etc etc? I could go on but I don't know if you'll get my drift (where can I buy test tones 5th or greatest hits?)
But then so is listening to actual music on your stereo and being content, instead of using an a accelerometer to measure something you in all probability cant hear
Old 17th November 2012, 03:42 PM   #107
Then you should probably do not post on this topic...
That's no difference. You know, I could use Mozart instead of test tones. It doesn't matter, I can still measure the resonances. That's signal theory.
You were talking about excitation of panel resonances. Audibility is another topic, and should be discussed separately.
Old 17th November 2012, 04:02 PM   #108
Mooly's Avatar
This is a warning to keep this thread civil. I've pulled a couple of posts... anymore will see points issued
Old 17th November 2012, 04:17 PM   #109
The "impedances" can't cancel out, because neither is a simple number. This isn't electronics or theoretical physics. There will be a resonance at some frequency, as Dave specified, but you seem to be arguing the "purely resistive" part is negligible.
Dave said:
Originally Posted by planet10 View Post
Fighting this is the natural energy dissipation of the material which is related to the relative dimensional differences between the material thickness and the wavelength in question.
To which you replied, "What?" The question hasn't been answered, but it would behoove you to figure out to what he was referring.
BTW. The measurements you posted ( Is enclousure strengthening needed? ) merely show that what you refer to as "heavily braced"... isn't.
Old 17th November 2012, 04:27 PM   #110
Yes, it is. And you should really take a lesson in it.
The "natural energy dissipation" is the resisitve part in the complex impedance, so at resonance only this works. But there is (nearly) nothing non-linear in the damping over a wide range of stress and strain, so every resonance is excited during playback of music even at low levels.
Bracing Howard Subwoofers 3 28th March 2012 01:55 PM
Transformer potting material? what material? rvrazvan Tubes / Valves 38 10th October 2011 05:02 PM
How much bracing is necessary? Frosteh Subwoofers 91 27th September 2011 11:59 PM
Enough bracing? Vikash Multi-Way 51 8th May 2006 05:58 PM
how much bracing is enough gwgjr31 Subwoofers 1 5th May 2006 06:57 AM
Copyright 1999-2017 diyAudio
