removable bottom to mount and access crossover?
Old 3rd November 2012, 09:12 PM   #1
Kooshball is offline Kooshball  United States
Default removable bottom to mount and access crossover?
How to most folks address crossover location and accessibility? I am building some 3-way monitors with curved sides similar in concept to the curved cabinets from parts express and the only place with enough area to mount the X/O is the bottom of the speaker.
To do this would require that the bottom be removable...How is this going to impact cabinet resonance since I can't brace it if it the X/O takes up the whole floor?
THX
Old 3rd November 2012, 09:23 PM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Since it is DIY I always advise to put it externally . Different from buying a 'black box'.
BTW I was reading today ( guess what sort of readings .... )
that the box servers for two purposes : protecting the speaker and containing the crossover
Old 3rd November 2012, 09:31 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
There's no law that says that a crossover all has to be in one lump. You could split the individual sections to form smaller boards to ease mounting. Or, as Pico suggests, mount it externally for easier tweaking. You know you will.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 3rd November 2012, 11:34 PM   #4
Do most folks use a removable access pannel or go in through the woofer cutout? I will have a 6" cutout but with 3" of height on the crossover I don't think (it) they can get through.
Old 4th November 2012, 12:02 AM   #5
pinkmouse's Avatar
Doesn't seem much point in only going with a 6.5" driver for a three way. I'd at least make it an 8", and a 10" would be even better.
Old 4th November 2012, 07:02 AM   #6
mmmh
Some say that a 6.5" at home is a gigantic size . The maximum allowable.
Old 4th November 2012, 07:20 AM   #7
pinkmouse's Avatar
Who says?
Old 4th November 2012, 07:49 AM   #8
The fact is that the loudspeaker must be able to put the listener in
the situation to make him(her/it the cat/dog) live again the recording,
and it's a matter of wavelenghts and reverberation ( of the original environment superimposed to the listener's one ) and to make him
to discern ,at every instant ...something like a decoding technique , what is playing and which instrument . That is valid mostly with classical music
where there is an established reality to compare with, it is not valid with electronic music or heavy processed one , so one can give attribution to
sounds and where they come from .
The size of the bass unit is referred mostly of how it is related to many
other magnitudes, such as the box size, shape, position in room and necessity
to play at the desired volume what the composition must express,nothing more nothing less, so there's no 'bomb the bass' or something else effect.
The size of normal rooms for normal audience ...2 or three people max
and positioning of the listener...which is presumably 1.5/2.5 m from the speakers , and the relation to the other (2 ways) driver units suggest that for a correct attribution to each instrument the size of the bass unit must not exceed 6.5" -
Old 4th November 2012, 07:54 AM   #9
pinkmouse's Avatar
Nope, don't agree with that at all.
Sorry for the Off-Topic Koosh.
Old 4th November 2012, 08:05 AM   #10
(It's also about mic capturing and...interaural distance ! )
removable bottom to mount and access crossover?Hide this!Advertise here!
Vandersteen 2C crossover access dgta Multi-Way 13 15th December 2015 05:45 AM
Removable Baffles LafeEric Construction Tips 4 22nd March 2012 06:17 PM
How did you mount crossover, John Krutke? JCNY Multi-Way 2 9th November 2005 07:33 AM
Sacd 1000 Bottom Pcb Access littlelabs Digital Source 1 11th October 2004 10:02 AM
Okay to mount crossover in bottom of cabinet? 1Time Multi-Way 4 18th February 2003 12:55 AM
