front tweeter for Revel Salon 1
Joined 2004
I would seek two replacement diaphragms and be done...
(Image from audiogon posting attached)
no way.....it means denaturalze the loudspeakers my aim is spend as less as possible for an original replacement! thanks anyway
Contact Scanspeak, probably they can advice you what could be current model which you can buy. Or buy it to get diaphragms.
Another advice: you need to change tweeters in pairs, or at least measure them after replacement to be sure that new and old are identical.
hi,
not having replay from S.S. I made a phone call.... well the D2904/9800 from classic line is the customizes tweeter used for the Salon, the only two visible differences are the dust cover on the dome and the second magnet for shilding. On monday someone from technical dep. will tell me if the electrical data are customized, if they are I will quit and buy the Revel one!
