#31 |
In the late 1950s, when stereo burst forth there were a number of schemes derived to "fill in the center hole" of stereo systems. The first consumer systems were housed in coffin like consoles with the left and right speakers at each end. Stereo affect was limited and the word imaging was not used in audio. Paul Klipsch did a number of papers on how to derive the "third channel", both pre and post amplifier'n and a number of systems were sold using a third channel speaker. You might want to look up some of his work.
I like the idea, and in this era, when most everyone gets their music through ear buds the single speaker concept could find a market. Have you tried isolating the three drivers to prevent modulation artifacts? Also co-ax speakers might get you better highs and 4 ohm auto speakers would give 8 ohms impedance instead of the 16 ohms sum your design would produce per channel. I'm going to build a system using some old auto speakers I have in the collection, along with 10" DVC woofer. |
#32 | |
Three speaker with linear stereo matrix is the system I'm using at the moment.
As pictured in post #4, the single speaker stereo is a simulation of the three speaker concept. Quote:
Sure coaxial elements might also perform well. Check again the impedance math, total is not 16 ohms what the amplifier sees but 12 ohms. In practice it is a bit lower due to the psychoacoustic filter. - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#33 |
Thanks for the reply Elias, and you are right on the impedance due to two the speakers in parallel seen as 4 ohms. I was looking at each independent leg. 4 ohm drivers would be seen as 6 ohms, a closer match to most modern amps. What typical values have you used in your filters with the drivers shown?
#34 |
For 8 ohm drivers good values for psychoacoustic filter as a starting point for experimentation can be found here:
It depends on the side wall reflectivity, room width and the specific drivers used, among others. So this is a guideline only ![]() - Elias
#35 |
Thanks for the reply. I did some experimentation and in my application I liked the sound with out the filter. One could build a system with various values selected by rotary switch for differing locations.
#36 |
I've been really busy of late with work/family !
I already have all the stuff needed, drivers, terminals, even cables ! Only need the box.... Hope to kickstart this project again really soon
http://gainphile.blogspot.com |
#37 |
I agree, the box is usually the hardest part
#38 |
Here is my version of the single stereo system. Three four inch mids with Piezos in a separate chamber with a sealed ten inch DVC with the crossover at 400HZ. OK, the color is strange but I had the paint left over and what else to you do with MDF?
It needs a narrow room ten feet of less to give stereo, however place it in a corner and you get some good imaging and of course more bass than you need. The Piezos are attenuated 6dB to match the mids and the center channel is down 3dB. An interesting experiment that saves you some wood and work but it was tried in fifties and sixties but never caught on. |
#39 |
Photo did not transfer so we try again.
#40 |
Very nice !
It will be a long weekend ... To build hopefully !
| Stereo Buffer with a single twin triode | Brit01 | Tubes / Valves | 43 | 29th July 2009 02:32 PM |
| Can single PCM56P act as stereo? | terranigma | Digital Source | 1 | 27th February 2007 09:29 PM |
| Single or stereo speaker evaluation | Salas | Multi-Way | 23 | 16th August 2006 09:13 PM |
| Stereo Single 4780 | traw | Chip Amps | 3 | 16th February 2006 11:39 AM |
| Meet belle lab, a new manufacturer of single driver fullrange loudspeakers | cdwitmer | Full Range | 14 | 11th September 2005 06:23 AM |
